20 Most Recent SanDisk 2GB Secure Digital Memory Card Questions & Answers
If you just bought this card, send it to the seller for a replacement. Or you can try to Remove Write Protection from SD Card by yourself.
SanDisk 2GB... | Answered on Mar 02, 2018
You can buy external SD card reader from any PC shops.2f961764-593f-49a5-bf4e-b98c9a8832fe.jpg
SanDisk 2GB... | Answered on Jul 18, 2013
printer usb connectivity may jam with avis better to plug card reader direct into usb ports on pc just a suggestion.
SanDisk 2GB... | Answered on May 16, 2012
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
SanDisk 2GB... | Answered on Mar 20, 2012
There's no chance of you messing up the memory card further. Once the memory card dried up, you should be able to use an external card reader to look at the pics on it. This type of memory is less susceptible to corruption and therefore it can take a lot more punishment.
SanDisk 2GB... | Answered on Oct 10, 2011
Well, formatting it immediately is not recommended. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article memory card not formatted - how to fix & recover to learn more the right fix step by step. Best regards.
SanDisk 2GB... | Answered on Sep 08, 2011
Let it dry out in a warm place for a few days. Then try it out, if it does not work then it is broken.
SanDisk 2GB... | Answered on Sep 25, 2010
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
SanDisk 2GB... | Answered on Aug 28, 2010
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • SanDisk 2GB... | Answered on Aug 27, 2010
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    Depending on the memory card, there should be a small switch or slider on the side which you can simply move up or down to enable or disable write protection (sometimes called Lock)
    SanDisk 2GB... | Answered on Apr 05, 2010
    if you have a USB cable for your camera, you might try to synch the computer with the camera and transfer your pictures that way.
    After you have your pictures on the computer, then you can obey your computer's wishes to format the card.
    Windows can be exceedingly picky about these SD cards, and I don't know why.
    SanDisk 2GB... | Answered on Mar 07, 2010
    Most likely, there is a switch on the side of the card. Flip it over from where it is now and then you should be good to go. If that doesn't work, select the file you are trying to delete and right click and go to properties, then unselect read only in the lower area of the window.
    SanDisk 2GB... | Answered on Jan 05, 2010
    Well,there's nothing that you can do except replacing it, because the memory card is damaged.
    SanDisk 2GB... | Answered on Dec 10, 2009
    basically nokia mode is meant only for those if u want to use ur for for internet nad short term applications..........for storage purposes data storage mode is used
    SanDisk 2GB... | Answered on Sep 03, 2009
    first check to see that it is not write protected (flip the switch on the side). if you cannot read from it and it still will not format, then it has probably been exposed to a static charge and is dead.
    SanDisk 2GB... | Answered on Aug 17, 2009
    The card may have failed on you or the write protect slide over enough to lock the card. Take the card out and looking at the label to the left is a notch on the side. In the notch will be a tiny button or slide. Move it to the top (away from the gold connectors) to unlock. If you still cannot delete you may have a dud card. You can try to reformat on a different computer or with a different operating system. For example windows won't work but Mac or Linux might work.
    SanDisk 2GB... | Answered on Jul 09, 2009
    You could try and send it to a data recovery center, but I think the only thing that can be done is to reset the memory card (the data is deleted by doing this). I have the device to do it, but as I told you before, it also deletes any data.
    SanDisk 2GB... | Answered on May 26, 2009
    Try to format your memory card on a pc. after formatting, try putting some songs or any other data on the card from PC and then insert it on to ur mobile phone.
    If is still does not work on mobile then you need to contact Nokia as the card is working fine.
    SanDisk 2GB... | Answered on May 25, 2009
    when u insert card into PC, a window pops up close it, then open the my computer, double click the removable disk (J) if this 1 does not open D click another removable disk , once it opens, open Ur pics, then left click the pic and hold the left button and drag the pic on to the open window u opened for the SD card or right click the pic and copy the past it in the SD window, hope this help
    SanDisk 2GB... | Answered on Mar 24, 2009
    SanDisk 2GB Secure Digital Memory Card Logo
    31 questions posted
    Top SanDisk Electronics - Others Experts
    Marvin
    Marvin
    ChinthakaJ
    ChinthakaJ
    Ekse
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
    View Most Popular
    • SanDisk Electronics - Others
    Most Popular Question
    memory card not formatted when
    • Electronics - Others
