20 Most Recent Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries Questions & Answers
My Duracell battery charger has a blinking red
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
9/26/2019 6:51:58 PM • Duracell NiMH... • Answered on Sep 26, 2019
I recently purchased a Duracell CEF14AU battery
Charging Normal Batteries runs the risk of explosion...
12/31/2012 2:44:01 AM • Duracell NiMH... • Answered on Dec 31, 2012
0answers
I charged my Duracell 2400 mAh batteries for 15
your lucky then,,, they take 16 hourse to fully charge unless you rapid charge them? a nasty thing to do to a new battery? all ways slow charge them first,,
never fast charge any battery only charge at whats called "the C10 rate!" they live much longer that way,
in other words slow charge when first charge,,,faster after that! ok,, did you not know you must "form the cells first" before you use them?
10/24/2009 7:34:09 PM • Duracell NiMH... • Answered on Oct 24, 2009
I bought KODAK NiMH 2400 mAh and it isn't
NiMH tends to have a "memory". What this means is that the batteries will get used to being only charged and discharged a certain amount. What could be happening is that the battery THINKS it is charged when it is not... or.. it THINKS it is discharged when it is not. You can try to recondition them:
  1. Charge them
  2. reset the charger and charge again
  3. put them in your device and drain them
  4. let them sit, drain them again
  5. recharge them
  6. drain them again
Do this a few times. If you don't notice an improvement, you may want to consider getting a new set of batteries - I would recommend lithium rechargeables.
7/12/2009 12:12:20 AM • Duracell NiMH... • Answered on Jul 12, 2009
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
3/1/2009 11:25:45 PM • Duracell NiMH... • Answered on Mar 01, 2009
I want to know if my Duracell 130 Watt AC/DC Power Adapter can be used to plug in a coffee maker into my cigarette lighter? I also misplaced the User Manual to this product. Can it be replaced. I beli
It's not a good idea to run anything that needs a lot of wattage through a power converter using a 12v cigarette lighter plug. Coffee makers work by using a resistant heater element and it might work, but you could damage the coffee maker or the adapter by doing so.
3/4/2015 2:25:36 PM • Duracell... • Answered on Mar 04, 2015
Dance compitition
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYaheatman101
3/31/2011 8:36:11 AM • Duracell... • Answered on Mar 31, 2011
2answers
Nsm performer classic
If your NSM Performer Classic jukebox is not accepting money and playing music, there could be a few different issues that could be causing this problem. Here are a few things you can try:
  1. Check the coin mechanism: Make sure the coin mechanism is clean and in good working order, and that the coin chute is not blocked.
  2. Check the bill acceptor: Make sure the bill acceptor is clean and in good working order, and that the bill path is not blocked.
  3. Check the credit display: Make sure the credit display is working properly and that it is displaying the correct amount of credits.
  4. Check the software: Make sure the software on the jukebox is up to date and that there are no errors.
  5. Check the selection buttons: Make sure the selection buttons are working properly and that the jukebox is able to receive selection inputs
  6. Check the amplifier and speaker: Make sure the amplifier and speaker are working properly and that the jukebox is producing sound.
If none of these steps resolves the issue, it is possible that the jukebox may be defective and require repair or replacement. In that case, contact NSM customer support for further assistance.
2/21/2023 1:01:50 AM • Electronics -... • Answered on Feb 21, 2023
How to delete all in my sony ericsson x10i
To delete all data from your Sony Ericsson X10i, you can perform a factory reset. Here are the steps to do this:
  1. On the home screen, tap the "Menu" button.
  2. Scroll down and tap "Settings."
  3. Scroll down and tap "Privacy."
  4. Tap "Factory data reset."
  5. Tap "Reset phone."
  6. Confirm that you want to delete all data by tapping "Erase everything."
Please note that this will permanently delete all data, including contacts, messages, apps, and settings. It's also a good idea to back up your data before performing a factory reset.
1/24/2023 4:54:21 AM • Electronics -... • Answered on Jan 24, 2023
Sky plus wont record and watch another channel at the same time says no signal
If your Sky Plus box is not allowing you to record one channel while watching another and is displaying a "no signal" error, there could be a few potential causes for this issue: Insufficient signal strength: Make sure that your Sky Plus box is connected to the satellite dish correctly and that the dish is pointing in the correct direction. Weak signal strength can prevent the box from tuning in to channels properly. Dish misalignment: If your dish is not properly aligned, it may not be able to pick up a signal from the satellite. You can try adjusting the dish yourself or contact a professional to align it for you. Technical problem with the box: There may be a technical problem with your Sky Plus box that is preventing it from recording and watching different channels at the same time. This can be caused by a hardware malfunction or a software issue. Subscription issue: Make sure you have the appropriate subscription package that allows you to record and watch different channels at the same time. Box is full: If your hard disk is full, the sky+ box may not be able to record or watch another channel. It would be best to check all the above points, if the problem persists, contact Sky customer service for further assistance. Why is my Sky saying no signal on some channels? Faulty Satellite Cable There are all sorts of things that can cause a cable to become faulty like age, condition, and whether it's damaged and weathering/ water ingress. To fix- A new coaxial cable or two new coaxial cables may need to be installed for Sky+ boxes and Sky Q boxes.
1/24/2023 4:41:53 AM • Electronics -... • Answered on Jan 24, 2023
Hard drive crashed on tascam dp02
A hard drive crash on a Tascam DP-02 digital recorder can be a major issue, as it can result in the loss of recorded audio files and settings. Here are a few potential solutions below: Check the connections: Make sure that the hard drive is securely connected to the Tascam DP-02. If the connections are loose, the hard drive may not be recognized by the device. Reformat the hard drive: If the hard drive is still recognized by the Tascam DP-02, you may be able to reformat it and use it again. This will erase all data on the hard drive, so make sure to back up any important audio files before reformatting. Replace the hard drive: If the hard drive is not recognized by the Tascam DP-02 or reformatting does not work, you may need to replace the hard drive. You can use a compatible hard drive with the same capacity or larger. Seek professional help: If none of the above solutions work, it may be best to take your Tascam DP-02 to a professional technician who can diagnose and repair the issue. It is important to keep in mind that, regardless of the solution, you will lose the audio files and settings that were stored on the hard drive. Backing up your files regularly is crucial to avoid data loss. reset my Tascam DP o2 - You May Try onces. To perform a factory initialization of the DP-02 turn the unit off. Hold the Up Arrow and Track Edit while powering the recorder on. You'll get a confirmation screen and then press the Yes/Enter button.
1/24/2023 4:38:08 AM • Electronics -... • Answered on Jan 24, 2023
I have a Keb Inverter and it's showing negative reading while on standby
Contact them direct. They will be interested to hear this. Did you check polarity with a test meter? https://www.google.com/search?q=keb+inverter+reverse+fault KEB Inverter - Contact Our Responsive Team Ad·https://www.kebamerica.com/ KEB America Is a Top Manufacturer Of Industrial PCs, HMIs, VFDs, Clutches, Brakes, & More. The Future in Control & Automation Technology w/ Customizable Products - Contact Us Today! Since 1972. Responsive Support. Customizable Products. Automation Experts.
DrivesUp to 1,000Hp; 230 & 460V classes. High Performance
ContactReach Out to Our Responsive Team Expert in Customizability
Contact UsSales Quotes Technical Support
About UsThe Future in Control & Automation Made in USA
1/23/2023 12:35:33 AM • Electronics -... • Answered on Jan 23, 2023
Why won't my cmt-ep505 turn on?
The fuse needs to be replaced then because it has blown on you or it might also be the fact that it was stopped working on you guys and you will need to buy a new one.Or it could be the plug or the power cord.
1/19/2023 7:11:47 AM • Electronics -... • Answered on Jan 19, 2023
KEB F5 = DC Bus voltage coming, Control card OK, but Display Power Not found, how do solve this problem.
If you are experiencing a "Display Power Not found" error on your KEB F5 Inverter and the DC bus voltage is coming and the control card is functioning properly, there may be an issue with the display or the power supply. Here are a few steps you can try to troubleshoot the issue:
  1. Check the power supply for any visible signs of damage or malfunction.
  2. Check the display for any visible signs of damage or malfunction, such as cracks or loose connections.
  3. Check the wiring and connections to ensure that they are secure and properly connected.
  4. Check the F5 Inverter's fuse and circuit breaker to ensure that they are functioning properly.
  5. Try resetting the F5 Inverter by unplugging it and waiting a few minutes before plugging it back in.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the F5 Inverter until the issue has been resolved, as continuing to use it may cause further damage.
1/7/2023 10:50:54 PM • Electronics -... • Answered on Jan 07, 2023
I have a problem with hybrid b1200. When in stereo mode input A is not working. Input B is working as if the mode is in parallel yet is in stereo mode
If input A is not working on your hybrid b1200 when in stereo mode and input B is working as if the mode is in parallel, it's possible that there is an issue with the wiring or connections for input A. Here are a few steps you can try to troubleshoot the issue:
  1. Check the wiring and connections for input A to ensure that they are secure and properly connected.
  2. Check the b1200's fuse and circuit breaker to ensure that they are functioning properly.
  3. Try resetting the b1200 by unplugging it and waiting a few minutes before plugging it back in.
  4. Check the owner's manual for any troubleshooting tips or information on common issues.
If these steps do not resolve the issue, it's best to contact a professional repair service or the manufacturer for further assistance. They will be able to diagnose the problem and recommend the appropriate repairs. It's also a good idea to stop using the b1200 until the issue has been resolved, as continuing to use it may cause further damage.
1/7/2023 10:47:11 PM • Electronics -... • Answered on Jan 07, 2023
How to connect usb flash drive on Toshiba model no.32AV615DB
it does not have USB input
12/17/2022 3:55:04 PM • Electronics -... • Answered on Dec 17, 2022
Have anyone BPS-8203 diagram ?
It doesn't exist. Take it to an electronics engineer for component testing or just buy a new one. https://www.google.com/search?q=BPS-8203+wiring+diagram ..
12/14/2022 7:16:11 AM • Electronics -... • Answered on Dec 14, 2022
Duracell NiMH AA/AAA Battery Charger with 4 Rechargeable AA Batteries Logo
Popular Tags
13 questions posted
Top Duracell Electronics - Others Experts
Robert McClure
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Duracell Electronics - Others
Most Popular Question
charged duracell 2400 mah batteries 15
  • Electronics - Others
