20 Most Recent Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for DX SLR Cameras Questions & Answers
My 55-200mm lens won't focus.
if other auto-focus lenses work, then it is likely that this particular lens has a defect I suggest you send it in to Nikon for servicing
11/25/2017 1:47:42 AM • Nikon... • Answered on Nov 25, 2017
2answers
My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
5/26/2015 8:43:00 PM • Nikon... • Answered on May 26, 2015
2answers
Clean inside lens fungus
If you realy have fungus in your zoom lens, you can't do anything. If it does not show on the pictures, just keep the lens dry. (use silica gel) If you want it it be repaired, it will cost more than an new lens.
12/2/2014 8:38:00 AM • Nikon... • Answered on Dec 02, 2014
Whatever you do, do not open the lens. You will never be able to reassemble it. If the fungus is adversely affecting your images, you need to take it to a qualified camera repair man or send it to a Nikon repair depot found on the Nikon website. If it is not affecting your pictures, I would just live with it.
6/18/2014 12:39:59 AM • Nikon... • Answered on Jun 18, 2014
2answers
Squeaking when try to focus. will not focus
My lens is also doing that same thing... and I just posted pretty much the exact thing you said...Mine squeaks and goes in and out really fast.. I do know that you can put the camera on manual mode and focus manually on mine, but would like to have the auto focus sometimes too. If I dont get an answer soon, I may send it in... I believe its a motor problem in the lens....
11/26/2011 6:25:39 PM • Nikon... • Answered on Nov 26, 2011
Not focusing
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
4/6/2010 3:34:49 AM • Nikon... • Answered on Apr 06, 2010
Nikon 55-200 is locked on 55 and won't extend to
Assuming that you've already tried a good firm hand on the zoom ring then all you can realistically try is to give the lens a few good firm slaps onto a desk to try and free up whatever has gone wrong. Brute force usually sorts them out, but it is "kill or cure". This lens lacks a macro mode, so this is not the usual simple case of adjusting a lens control and then slapping your forehead with embarrassment...
The lens is otherwise uneconomic to repair as it's one of the cheaply built kit lenses and so you can easily obtain another for less than the cost of repairs.
1/30/2010 7:47:37 PM • Nikon... • Answered on Jan 30, 2010
0answers
Is is worth fixing?
infopgdesign,
That's a close call, depending on how bad the housing is broken, there may be lens alignment issues, the adapter ring or the housing body may be cracked, take it in to a shop so they can look it over closely to help you decide if you should send it to Nikon for repair which depending on the severity of the damage will determine the cost. if it's close to what you paid for the lens, save your money and buy a replacement, maybe the VR version of that lens if it wasn't.
randy320sgi
1/18/2009 5:59:57 AM • Nikon... • Answered on Jan 18, 2009
How to achieve full zoom with a Nikon 55-200mmf/4-5.6G ED lens?!
1) What camera body are you using?
2) I do not understand your assertion that it automatically zoomed in. Zooming is a manual function. The automatic functions of your lens pertain only to focusing on of the subject so that your picture is sharp and ensuring that the correct amount of light is admitted so that you have a correct exposure.
3) Are you sure you were turning the zoom ring and not the f-stop ring? The zoom ring is labeled 200 on one end of the scale and 55 on the other. It is also the widest ring on the lens barrel. When you rotate it, the physical length of the lens will lengthen as you rotate it clockwise (viewed from behind the camera) and shorten as you rotate it counter-clockwise.
4) For reference, at 200mm the angle of view on your lens should be 10 degrees and at 55mm about 40 degrees.
12/31/2008 5:09:12 PM • Nikon... • Answered on Dec 31, 2008
Lcd display screen not working on my new d7500 nikon
go to service center....this is not possible by you...
11/20/2022 7:27:21 PM • Nikon Cameras • Answered on Nov 20, 2022
Why does my Nikon Coolpix W100 have a black screen when I turn it on
Is the Lens shutter open on it?
11/13/2022 6:06:37 PM • Nikon Cameras • Answered on Nov 13, 2022
Nikon B500 camera. I put a new memory card in my Nikon B500 and the camera says 'card not present'.
Is it this type of card? The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB) And is it less than 128GB? Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards. https://www.google.com/search?q=nikon+coolpix+b500+compatible+memory+card ..
11/6/2022 11:17:40 PM • Nikon Cameras • Answered on Nov 06, 2022
0answers
Nikon D40 screen loop, can't use it
Hi, Please make sure that the camera has an SD card inserted into it. If it does, then you might have to switch out the current card for a new one. Thank you.
10/11/2022 1:16:01 AM • Nikon Cameras • Answered on Oct 11, 2022
The battery door on my Coolpix s7c will not close flat even though the battery is a Nikon
Inserted the correct way round? Wrong battery for the model you have? https://www.google.com/search?q=Coolpix+s7c+battery ..
10/8/2022 5:39:32 PM • Nikon Cameras • Answered on Oct 08, 2022
Nikon B500 isn't Turning On?
the battery is original
8/26/2022 8:45:56 AM • Nikon Cameras • Answered on Aug 26, 2022
Camera lens help required.
This issue is caused by fiedd of view angle and means that the lens is not compatible with the camera. You can set the F-stop higher and sometimes reduce that effect.
8/8/2022 5:04:49 PM • Nikon Cameras • Answered on Aug 08, 2022
Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for  DX SLR Cameras Logo
19 questions posted
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
clean inside lens fungus
  • Cameras
