20 Most Recent Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Questions & Answers
Automatic turn off is generally a security several electronic units have to avoid further damage to the unit.
Your unit probably has a shorted capacitor, transistor or any other electronic component damaged
The only way to pinpoint the cause is to have it examined by an electronics specialist who can tell you what the cause is, how to fix it and the $$$ value to repair
Yamaha 5.1-Ch.... | Answered on Dec 27, 2017
You could try cleaning both the female ports you are connecting to along with the cables ends you are interting with DeOxit. Sometimes they both develop oxidation over time. Good luck! http://store.caig.com/s.nl/sc.2/category.188/.f
Yamaha 5.1-Ch.... | Answered on Sep 27, 2017
Why would you want to?
Look up 'white van speaker scam' on the internet.
Yamaha 5.1-Ch.... | Answered on Apr 12, 2015
Yes, any TV will work with any surround system. It all depends on how you wish to connect them together. That all depends on what kind of inputs/outputs you have on both the TV and the amplifier. Too difficult to advise without being there and having the operating manuals for both the TV and 5.1 system.
Yamaha 5.1-Ch.... | Answered on Aug 26, 2014
It think U should check the video cable .it may be loose.
Yamaha 5.1-Ch.... | Answered on Jul 26, 2014
MY INTEX 2.1 SPEAKERS BOTH SPEAKERS ARE WORKING OK, PROBLEM IS IN WOOFER, AND THE SYSTEM IS CONNECTED WITH pc
wHAT COULD BE THE POSSIBLE PROBLEM???
Yamaha 5.1-Ch.... | Answered on Nov 09, 2013
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Yamaha 5.1-Ch.... | Answered on Apr 22, 2013
It's in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5230-Receivers-manual/id/319dj893/t/2/
Yamaha 5.1-Ch.... | Answered on Mar 17, 2013
As long as your television and system both have (audio/out jacks from tv, audio/in to system) and cables it should hook up. Not real sure what you mean about directions for the remote, the system I have didn't come with directions just starts working as soon as the system is hooked up. Hope it helps
Yamaha 5.1-Ch.... | Answered on Feb 08, 2012
That setting being 'wrong' shouldn't kill anything on its own. It's only 2 ohms difference and the rubber hits THAT road only at very high outputs.
Many switchable-impedance amps have warnings to make sure the switch (with power OFF) is completely in one or the other position (implying sloppy switching hardware).
If you look in the manual for the unnamed reciever it may elaborate on that theme.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Yamaha 5.1-Ch.... | Answered on Sep 09, 2011
Hey I am having the same issue. I hope you found a solution..if you did PLEASE let me know..you can email me at [email protected]
Thanks in advance
Yamaha 5.1-Ch.... | Answered on Aug 02, 2011
Resolve the reason the digital bitstream keeps disappearing or being corrupted. What model? What source(s)?
Yamaha 5.1-Ch.... | Answered on Aug 01, 2011
open the unit check the fuse if blown,ic power regulator
Yamaha 5.1-Ch.... | Answered on Jul 29, 2011
Yeah, read the manual.
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
Yamaha 5.1-Ch.... | Answered on May 29, 2011
Between us, only you can diagnose that.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Yamaha 5.1-Ch.... | Answered on Apr 19, 2011
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
Popular Tags
73 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
intex 4 1 speakers but woofer not
  • Audio Players & Recorders
