20 Most Recent Logitech Precision Stereo PC Gaming Headset Questions & Answers
what operating system is his computer ? Windows 7 ??? https://support.lenovo.com/au/en/solutions/ht073424
Logitech... • Answered on Feb 12, 2018
problem is lately all the higher end headphones and usb sets use microthin wires. there is fine strands like as thin as a string and woven into it is 2 or 3 micro thin copper strands. it may be possible but very difficult...
Logitech... • Answered on Oct 04, 2009
go to your sound panel and check to see it is recieving sound, if it is, its the game, if its not, make sure the mic is turned on by the switch on the volume control on the headset itself, then pust the mic jack in all the way as hard as you can, if it works good, if it doesn't it is a hardware issue
Logitech... • Answered on Jul 17, 2009
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected. Hope this helps.
Logitech Radio... • Answered on Jan 14, 2018
is the minijack plug compatable with your mike
Logitech Radio... • Answered on Dec 28, 2017
if you followed the instructions and doesn't work return to place of purchase for refund or replacement
Logitech Radio... • Answered on Aug 29, 2016
easier to just replace the cable.
Logitech Radio... • Answered on May 19, 2014
If you do not have the Bluetooth dongle (plugs into a USB port) you should contact Logitech for a replacement. Alternatively you can also look for one second hand via craigslist, ebay, etc.etc.
Logitech Radio... • Answered on May 04, 2014
I believe this is a Bluetooth headset, have you tried replacing the batteries? If yes, try to delete the existing Bluetooth connection and try to create/add a new connection. 70% chance it will work, if not, the headsets need to be replaced.
Hope this helps.
Logitech Radio... • Answered on Apr 16, 2014
Logitech Precision Stereo PC Gaming Headset Logo
9 questions posted
Top Logitech Radio Communications Experts
Michael Thomas
Michael Thomas
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Radio Communications
Most Popular Question
microphone not working
  • Radio Communications
