20 Most Recent Braun 7000 Series Foil and Cutterblock Questions & Answers
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Braun 7000... | Answered on Dec 30, 2014
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
Braun 7000... | Answered on May 28, 2014
If you are unable to locate parts in your country, you can order from shaveroutlet.com and have them delivered to you
Braun 7000... | Answered on Aug 07, 2013
For Braun 7000 series shavers, you will find replacements at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-foil-and-cutter-p-141.html
Braun 7000... | Answered on Jan 18, 2013
You can change the batteries in 7000 series shavers. You will find the correct battery type at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for installation videos
Braun 7000... | Answered on Aug 19, 2011
After reviewing your Problem , My think says , its a Machine Problem... or may be its a Heat Problem , the Reason of Heating is that , the blade of machine is not installed Correctly , so Blur your Machine , clean it all ,then it will okey.
Braun 7000... | Answered on Jul 24, 2011
You will find a helpful video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Braun 7000... | Answered on Jan 18, 2011
My Pulsonic Razor that I received for Christmas will not run on battery, or with the plug supplied. I have tried just about everything I can think of. Is there a way to solve this problem? I do not have a receipt as it was a gift and am quite certain it would cost me a small fortune in order to fix it at a Braun Service centre.
Please help me if you can. TY
[email protected]
Braun 7000... | Answered on Aug 08, 2010
Hi, yes these batteries only have a limited life unfortunately. To prolong the life of your battery, always ensure the batery is completely flat before charging and always charge fully but do not leave charger on after charge has completed.
Hope this helps
Braun 7000... | Answered on Aug 01, 2010
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
Braun 7000... | Answered on Jun 29, 2010
broken screen braun 549
Braun 7000... | Answered on May 29, 2010
The red light indicates that the battery is low and needs recharging
You didnt mention your model number but I have provided a link below for the most common 7000 series shaver user manual
http://www.service.braun.com/line/SH/S5493/S5493_14_NA.pdf
Braun 7000... | Answered on Feb 07, 2010
Braun 7000 Series Foil and Cutterblock Logo
30 questions posted
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
T.Johns
Level 1 Expert
bigcheapskat
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Health & Beauty
Most Popular Question
batteries replaced in 7000 series
  • Health & Beauty
