20 Most Recent Sony Dual-Deck Cassette Player/Recorder with Dolby Noise Reduction Questions & Answers
If the laptop has an audio in socket then all you need is one of these: Amazon stock them. 3.5 plug to two RCA plugs.
Sony Dual-Deck... | Answered on May 07, 2016
The unit need service work ad maybe a new belt or other. It would need to be looked at as to why it does not work. There is no easy answer.
Sony Dual-Deck... | Answered on Jan 02, 2015
Look at Marrs Communications for the belt kit. If you want to measure and subtract 5% you can do that but it might be a lot more trouble.
It is old and need maintenance so you will need to take it out and take it to a repair facility.
Sony Dual-Deck... | Answered on Dec 14, 2014
Kan slijtage aan of een gebroken/gebarsten tandwieltje zijn. In beide gevallen moeilijk te herstellen. Bij goedkope decks kan het ook een gebroken aandrijfriempje zijn.
Sony Dual-Deck... | Answered on May 24, 2014
The unit needs service but may not be worth the cost of the job. Dual cassette decks in all brands are constructed very poorly- that is why I do not own one but have dozens of other good decks that still work after 30 years.
Sony Dual-Deck... | Answered on May 15, 2013
The power supply would have to be examined and the problem may be a burned out regulator or as simple as a thermal broken solder joint. One reason the power supply gives out is due to worn out capstan motors that are drawing too much current- the speed of the deck can give indication of this. There is sometimes noise that comes from DC motors with worn brushes- the brushes get to the point that they wear through and break off0- that is when they make noise. New motors are available.
Sony Dual-Deck... | Answered on Feb 20, 2013
I have the same unit...when it is "ON" ,plug the power cord off and than try to open the cassette door..
the head mechanism keeps the cassette in,power off will release it..
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Sony Dual-Deck... | Answered on Feb 02, 2013
Ive used o-rings from home depot with no issues before....I did a little research and the part numbers match to
http://www.ebay.com/itm/SONY-TC-WR665-WR670-WR690-WR701ES-Double-Cassette-Belt-Kit-GTD-5-YEARS-/140828351357?pt=US_Home_Audio_Cassette_Decks&hash=item20ca061b7d
I would investigate on your own to make sure, but the parts cross referenced
Sony Dual-Deck... | Answered on Aug 20, 2012
you need to open it manually.take out the cover of the player by removing the screw.after removing the cover you can now access the deck mechanism.manually push the pin that serves as lock that holds the cassette door gently push it down to free the door.because the decks do not move check the belts for the mechanism make sure the belt is not loosen or worn out and cut off.replace it with a new one if you found it deffective.
make sure also that there is power on the deck motor you can use a tester to measure the voltage on the circuit good luck!
Sony Dual-Deck... | Answered on Dec 30, 2011
It could be either a worn roller, but more likely a belt problem. It's often a good idea to replace the belt(s) as the are rubber and wear out easily. They are not expensive either. Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Make a note of how it fits before replacing them, that's if you can do it yourself of course!
Sony Dual-Deck... | Answered on Apr 22, 2011
I have the same tape deck. To do a copy on this machine you first press the normal speed button below synchro dubbing, then hit the pause button on the recording side to start the copy. It will automatically start both decks.
And to stop the recording hit either of the stop buttons.
Sony Dual-Deck... | Answered on Jan 13, 2011
Sony Dual-Deck Cassette Player/Recorder with Dolby Noise Reduction Logo
Popular Tags
29 questions posted
Top Sony Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony tc wr770
  • Audio Players & Recorders
