20 Most Recent
AT&T Motorola RAZR2 V9 Cell Phone - Purple Questions & Answers
Cannot get puk code for my blackberry perl
These directions are for an AT and T phone, but other than that, are the same for any carrier. A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card. You can obtain your phone's PUK code from your carrier in one of these ways: Log in to Your account.online Use a Technical Support Chat Contact your carriers Customer Care Get Your Phone's PUK Code Online Go to the Phone/Device page. From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card. Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code. Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
I need an unlock code
To unlock the Mobile so many method available ....But they leads to Data lose....Unlock code is Best Method..they are safe method...I used the Code to Unlock my mobile,....You can get the unlock code here
http://www.unlocking4u.com/motorola-v9/rs6wp9/ to Unlock Your Mobile from the Network lock....
You check for your locked Network it's Country also.
Callers can't hear me when i talk
Look to see if it is Muted. Remember if it says "Unmute" it means it IS muted. Push the button to unmute it. Sometimes it gets bumped accidentally...
Forgot unlock code for phone unlock cannot get
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
