20 Most Recent Electrolux 30" Electric Hybrid Induction/Radiant Cooktop - Stainless-Steel/Black Questions & Answers
0answers
What does error F93 mean
1/18/2014 10:15:24 PM • Electrolux 30"... • Answered on Jan 18, 2014
What do error codes E51, E52, and E53 indicate?
This link lists the error codes for your cooktop: Needapplianceparts com Specifically, it's a "sensor break" in your front and center burners. The solutions they recommend: * Verify element temperature sensor is correctly connected to the generator circuit board * Replace element if temperature sensor resistor value is not approximately 1000 ohms (blue wires) at room temperature * Replace associated generator circuit board
1/13/2014 2:05:24 AM • Electrolux 30"... • Answered on Jan 13, 2014
0answers
0answers
0answers
0answers
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
12/30/2012 10:14:29 AM • Electrolux 30"... • Answered on Dec 30, 2012
ELECTROLUX ERROR CODE E95
Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
8/9/2012 7:34:18 PM • Electrolux 30"... • Answered on Aug 09, 2012
Electrolux Induction Cooktop Kite C-561 3611 00 Rev B- All the lights are turned on
We aren't Electrolux, we are FixYa dot com, and you appear to have fixed it. Resetting the board would simply involve cutting the power to it. Induction cooktops are a relatively new innovation to the home markets are in general, all Induction cooktops fail due to failing electrical components. I have a 50 year career in catering, and 10 years with induction units. Even the catering quality units with a single hob that cost $1,800 fail in 18 months to 2 years. Contact Electrolux direct and ask if they can find the failed component and repair the board. https://www.google.com/search?q=%E2%80%8BContact+Electrolux ..
7/25/2023 2:18:48 PM • Electrolux... • Answered on Jul 25, 2023
I have an Electrolux cooktop model # EW36CC52GS. Changed a burner. There are 2 identical connectors on the terminal board which one do I plug the top back into, I didn't see second connection.
there should be identifier letters on the terminal board use a magnifier follow the lines that come from each connection on the board.
11/29/2019 3:54:30 AM • Electrolux... • Answered on Nov 29, 2019
My Electrolux induction hob showing error massage E9, Advice please
https://www.support.emea.electrolux.com/en-uk/Hot/Hob/Hob_displays_error_message_E9
11/28/2018 3:44:53 PM • Electrolux... • Answered on Nov 28, 2018
Electrolux 30" Electric Hybrid Induction/Radiant Cooktop - Stainless-Steel/Black Logo
22 questions posted
Top Electrolux Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Cooktops
  • Electrolux Cooktops
Most Popular Question
electrolux error code e95
  • Cooktops
