20 Most Recent
Breville Gourmet Rice Cooker - Stainless-Steel Questions & Answers
How do i get the screws out of a breville toaster
I took a 3/16" common (straight) screwdriver bit from one of my cheap universal driver bit sets, chucked it vertically in my shop vice, mounted a grinding disk in my Dremel tool, and ground a 1/16" wide by 1/16" deep slot in the center of the bit. It worked perfectly. A hacksaw blade carefully placed could produce the same tool.
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
