20 Most Recent Verizon Communications HTC XV6800 Cell Phone - Blue Questions & Answers
Hello friends, I am sharing an Professional repair shop which will help you truly if you need repair phone or just started repair.
Recommend a convenient phone repair website: http://www.vipprogrammer.com, it comes from China One-Stop Shop - Professional-grade Phone Repair,
I am sure you all will like over there repair tools. dont forget to share if you like it.
They are free to consult, I hope that the programmers I recommend can help you.
Original universal programmers Online Shopping Store from China
Verizon... | Answered on Oct 13, 2017
hmm, the only way you won't be able to send messeges, and receive that notification is 1. you have bad reception, 2. the phone you sent it to has your number blocked. 3. your phone is using an incorrect carrier sim card.
Verizon... | Answered on Aug 21, 2017
Contact your cell phone's service provider and they can walk you through the setup procedure.
Verizon... | Answered on Apr 20, 2017
Usually you will need to remove the back cover, then the battery to expose the sim card. Push in on the sim card and that should trigger a relase which will eject the sim card.
Verizon... | Answered on Jul 07, 2014
Call verizon and tell them you are locked out of your phone.
Verizon... | Answered on Oct 01, 2013
it can be used by unlocking with new iemi no.
Verizon... | Answered on Dec 28, 2012
Hello
First you have to activate mobile internet or gprs connection..
To do so please call your sim service provider and get the details on activating it..
While doing so they will send a settings that you need to save it or install it on your mobile..
Then you can start using internet on mobile..
Thank you for using fixya..
Please rate me on fixya to continue my future assistance..
Verizon... | Answered on Oct 14, 2011
Unusual problem. Check the settings to make sure theirs not a way to disable Caller ID. Give Verizon a call and see if they can find out whats going on.
Verizon... | Answered on Sep 26, 2011
You can get from service provider............
Verizon... | Answered on Aug 17, 2011
I wonder if you have Windows Mobile Device Center running, as well as Outlook (for calendar, contacts, tasks and e-mail synchronization) installed on your PC. Link for downloading WMDC is here, anyway, for your convenience.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Verizon... | Answered on Nov 10, 2010
You will have to make sure the carrier that your trying to use allows other carrier phones on there system. If they do then you will have to get it flashed over. You can contact wireless image in denver co. They can answer all your questions.
Verizon... | Answered on Oct 19, 2010
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Verizon... | Answered on Oct 06, 2010
i know the site from where you get your unlock code.when i suffered with the problem my friend suggetd me the site when i visited i got mine code from there.click here to get your unlock code.
hope this helps..
Verizon... | Answered on Sep 29, 2010
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Verizon... | Answered on Aug 02, 2010
try to reprogram by dialing *22899 and send
Verizon... | Answered on Jul 11, 2010
Unfortunately VERIZON phones do not use SIM card because they are cdma phones and TMOBILE uses sim cards (they are gsm phones) therefore you would not be able to use that phone with tmobile. Sorry
Verizon... | Answered on Jul 07, 2010
You do not need internet access but it depends if your service provider has enable this on your account.The best thing is to call your service provider and request further information..Normally they cost a bit more and it will vary from provider to provider.Hope this helps.
Verizon... | Answered on Apr 21, 2010
If you tried upgrading the software to Windows Mobile 6.1, there could be a possibility that the software is not compatible with the phone, or it could be corrupted.
First, verify the supported program of the phone. Next, check your the current program running on the phone.
Contact the manufacturer to ask them, what version of program that would work best with your phone. The only thing that you may try is to upgrade the firmware of the phone.
If you're going to think, draining the battery fast has something to do with the physical connection only, but the truth is, software or firmware is also responsible for that. Once you upgraded your software, there are some components that will work fast, that might cause the battery to drain out.
Contacting the manufacturer for second opinion is the best thing to do.
Verizon... | Answered on Mar 09, 2010
Here is a video tutorial for the Sprint Mogul, which is much like the xv6800.
http://www.youtube.com/watch?v=1lHXgVBd3j8&feature=related
Seems pretty complicated, but once you dive in its not so hard. Some people on ebay sell the faceplates and even include the tools to change it. Beware though that the Sprint and Alltel versions will not fit your xv6800. I am still trying to get one to work on my xv6800 with no success. I advise sticking to verizon's blue housing and leaving out the headaches I have had. Good Luck!
Verizon... | Answered on Feb 09, 2010
Verizon Communications HTC XV6800 Cell Phone - Blue Logo
57 questions posted
Top Verizon Communications Cell Phones Experts
Marvin
Marvin
James Bradburn
James Bradburn
Muntejaya Ginting
Muntejaya Ginting
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Verizon Communications Cell Phones
Most Popular Question
am not allowed go internet says
  • Cell Phones
