20 Most Recent
Maytag EPICz Electric Dryer Questions & Answers
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Clean lent filter
The unit is seeing a restriction in air flow disconnect the exhaust at base of machine turn to air dry or fluff you should get good air movement coming out of the exhaust I will assume the machine worked when new if flow is weak then there is lint in the blower air passage from the machine if good you will know the difference the the restriction is in the exhaust exiting the house on one occasion i did encounter a bad control if everything passes the test an dryer is operating correctly and you still have a light leave it control is not cheap for an annoying light
No heat
Check circuit breaker it will still run but not heat if part of the breaker is tripped
