20 Most Recent Dell XPS M1330 Laptop Questions & Answers
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Dell XPS M1330... | Answered on Nov 23, 2016
Just insert the Windows setup disk, or goto the restore partition. Whan the operating system says I already see a windows installed, shall I repair that, answer no and say install new operating system. After that you have to install several )(if not many) updates, but the machine will be clean.
When you read something like you have a rootlet or something like that, try to use Fdisk and clear all partitions. Be careful it could be you have a restore partition you need to reinstall everything, so try to save that partition first before using Fdisk. Any way, if you are not familiar with Admin work you should not use Fdisk at all.
Dell XPS M1330... | Answered on Jan 23, 2015
Error code 2000-0322 is a LCD INVERTER error but you wanna buy both just in case. I hope this is helpful.
how to replace inverter
how to replace screen
Dell XPS M1330... | Answered on Aug 11, 2014
hi, BIOS or CMOS password are usually reset by a jumper or shorting pins. if your are the owner of the laptop you can go the brand site and ask for a universal default password. this is the safest way. however, if you don't want these hassles you can follow below procedure but with risks. it is for you to follow or not.
1. when you prompt the with password. type anything.
2. 3 wrong password will show "system disabled" with codes.
3. Turn off your computer, remove the adapter and battery on your laptop for a couple of seconds.
Reboot your system and see if password is disabled.
im not responsible for any damage for system. it's your own risk.
thanks
Dell XPS M1330... | Answered on Mar 31, 2014
It is the problem with your windows. Your window is corrupt and now you need to reinstall or upgrade the window.
Dell XPS M1330... | Answered on Jul 26, 2013
Update the driver of your dvdr so that you can make sure that the operating system is communicating with the dvd. You can use RadarSync to automatically update the driver.
David
Dell XPS M1330... | Answered on May 31, 2013
If you cannot start the laptop, you cannot flash the BIOS. You can ship the unit to me, and I'll recover the BIOS. You can email me at [email protected]
Dell XPS M1330... | Answered on Feb 17, 2013
no errors...? just a black screen..? unbelievable...
a computer can always log missing files... and that could result to errors...
a black screen with no errors can be a hardware problem...
Dell XPS M1330... | Answered on Jan 19, 2013
The Windows firewall? Open Control Panel, Windows Firewall, Turn windows firewall on or off. OR Security Center.
Dell XPS M1330... | Answered on Dec 30, 2012
This could be a problem with your router. Call your internet provider and tell them your problem and see what they say. If not, it could just be a problem with your wireless card/modem in your laptop :)
Dell XPS M1330... | Answered on Aug 01, 2012
Go to control panel and look for cameras then start it up.
Dell XPS M1330... | Answered on May 01, 2012
Actually you have to burn the photos to the disc. See if you have some other type of burning software such as Nero, Roxio, etc.
Dell XPS M1330... | Answered on Apr 30, 2012
Have you tried using the Eject button on the controls above the Function keys on your Dell XPS M1330 laptop to eject the disk from the optical drive?
If the above does not solve the problem then you may need to refer to the Service Manual for your XPS M1330 which has information on how to remove and replace the Optical drive if this has failed.
Dell XPS M1330... | Answered on Jan 05, 2012
You must be talking about the keyboard not the motherboard. If allot of keys and characters not working you might have to have the keyboard replaced.
Dell XPS M1330... | Answered on Feb 25, 2011
Dell XPS M1330 Laptop Logo
72 questions posted
Popular Products
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
XPS Dell
  • XPS Dell
Most Popular Question
get disk out xps m1330 laptop
  • Computers & Internet
