20 Most Recent Maytag 30" Built-In Single Electric Wall Oven - Black Questions & Answers
The oven control board is defective--most likely the electronic control chips have been damaged and are causing a crossing of the functions.
Maytag 30"... | Answered on Oct 04, 2018
without knowing the model I'm going to give you the most probable issue.
The wires that connect to the element plug in have become brittle and bad there's no more connection.. they need to be repaired.
I'm sure you know this but....shut off power to the unit while working on it.
best to you.
Maytag 30"... | Answered on Sep 01, 2018
make sure the door is shut tight and making the switch
Maytag 30"... | Answered on Feb 02, 2017
Hello. I need the model number of your unit to help you accurately with exploded parts diagrams and part numbers. From what you describe, it sounds like you have a defective oven temperature sensor. There are only 2 things that govern temp in a range--the EOC(main oven control board) and the temperature sensor. It's connected to the main board by a 2-wire harness. Usually, there is a connector at the end of the short pigtail coming from the sensor. The contacts in the sensor can oxidize, breaking electrical connection or, the signal can be lost due to a broken wire, loose connection, etc. Most often, the sensors will have an electrical resistance of approximately 1100 Ohms +/- 10%. Usually, if the sensor checks good, the main board is the culprit. Hope I helped you!
Maytag 30"... | Answered on Oct 11, 2015
can,t change normally,this task should only by a licenced specialist
Maytag 30"... | Answered on Oct 25, 2014
check to mains plug tightly in mainboard,,, then check circuit breaker =it should be on position
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Maytag 30"... | Answered on Jun 30, 2014
Unplug the stove, then take the wires off the heating element. Using an ohm meter check for continuity across the two pins. If none replace element. If there is, then he contactor in the unit is probably bad.
Maytag 30"... | Answered on May 24, 2014
oven will not ignite?
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Maytag 30"... | Answered on Jan 17, 2014
I have the same problem. I can't see how maytag can say there are no quality issues since they don't track how many calls they get about the same problem.
Maytag 30"... | Answered on Sep 30, 2013
The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Maytag 30"... | Answered on Jun 29, 2013
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Maytag 30" Built-In Single Electric Wall Oven - Black Logo
95 questions posted
Top Maytag Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
maytag wall oven model mew6530dds
  • Ovens
