20 Most Recent Jobar RX Optics 35 MM Negative and Slide Scanner Digital Image Converter JB5323 Questions & Answers
Most VISTA software and drivers will work with Windows 7. If you get an error trying to load it, it may be because the installer looks for the OS identifier and it is not XP or VISTA. IF that happens, you can right click on the installer file/icon, and select "compatibilty mode" for VISTA to attempt to make it work. This is rarely necessary, however.
Jobar RX Optics... | Answered on Aug 31, 2016
The manufacture would be the primary source if a driver does exist.
Jobar RX Optics... | Answered on Apr 05, 2016
hi dear,
i replaced cartridge of t60 but a problem acquired cyan cartridge not detected but if any cartridge plug out from head cyan is detected.
please find enclosed herewith Problem pics & solve the problem8953a616-9cec-4162-99e9-186b6077460c.jpg655a04ed-9614-4d9b-9032-e6daedf26a9f.jpg
Office Equipment... | Answered 3 days ago
Tip
How to Dismantle a Xerox AX7-19 Monitor
The article regarding the dismantling of a glass fronted Xerox monitor misses one important detail. When placing the back of the monitor on your lap, the bottom edge, BELOW the switches should be slid up in the direction of the top of the monitor. Approx 6mm. DO NOT attempt to prize the glass off the base like I did, trying to follow the previous instructions. To replace, place the the glass on the base, approx 6mm proud of the top edge of the monitor, then slide the glass downward to lock in to the lugs. The two rear screws then simply hold the glass in place, The fixing lugs act like a bayonet fix. Drop in then slide down. I hope this helps with this repair.
on Jan 09, 2021 | Office Equipment & Supplies
Call +1-866-231-0111 Canon printers are subsequently one of the most trusted user brands around the globe, making these printers more demanding than ever before. Canon printers tend to suffer from some error codes despite their amazing features, which for some time hinder users from using printers. There are significant problems with Fix Canon Printer Error Code 2, 140, 21
Tips to Solve Canon Printer Error 2, 140, 21
Here we will discuss all the aspects which will make you to tackle the most common, these all methods have been introduced by the professional experts of the issue.
Method 1- Stop the Function of printing
The Canon Printer Error 2, 140, 21 is mostly occurs in the processors of scanning a document over. But the good thing is that it can be easily solve with the help of these instructions that you will give to your system, that will result to stop the printing the document. Follow these Quick steps as mention below:
1. Go to the start menu
2. Search for the Control Panel
3. Click on the option of Device and Printers
4. Tap on Printer
5. Tap on "Stop Printing" option
Canon Printer Customer Care Number +1-866-231-0111
If the mistake occurs, call for instant assistance at the Canon Printer Customer Service Number +1-866-231-0111. We are a 24 * 7 group of well-qualified and experienced engineers. We are to help you with your toughest printing mistake. Our techies strive to provide analyzed responses to all inquiries linked to the client
Office Equipment... | Answered on Jan 07, 2021
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Office Equipment... | Answered on Dec 30, 2020
Open all the doors, remove the toner cartridge or the inkjet cartridges in your mystery device. Look inside with a powerful flashlight. You are looking for a small piece of torn paper that is covering a sensor.
Please, in future, all questions on Fixya must include full
make model (what it is)
Office Equipment... | Answered on Dec 27, 2020
Contact the manufacturer/distributor to request the manual.
Office Equipment... | Answered on Dec 26, 2020
  1. Make sure that the power is turned on.
  2. Open the front cover (A). ...
  3. Open the paper output cover. ...
  4. Push down the empty FINE cartridge until it clicks. ...
  5. Remove the FINE cartridge. ...
  6. Take a new FINE cartridge out of its package and remove the protective tape (D) gently.
Office Equipment... | Answered on Dec 24, 2020
I moved you from the L.A. Galaxy category!
Take it apart, or grab the plastic cover with a pair of pliers and try to pull it out without damaging anything.
Or contact Fellowes direct.
https://www.google.com/search?q=Galaxy+e500
Office Equipment... | Answered on Dec 23, 2020
Jobar RX Optics 35 MM Negative and Slide Scanner Digital Image Converter JB5323 Logo
6 questions posted
Top Jobar Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Jobar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Jobar Office Equipment & Supplies
Most Popular Question
driver mac osx 10 11 3
  • Office Equipment & Supplies
