20 Most Recent Maytag Over-the-Range Microwave Questions & Answers
You are going to need the installation template and the mounting bracket. You should be able to get these from the original manufacturer.
Maytag... | Answered on Dec 30, 2017
Sounds like the magnetron tube is no longer working. Check for a bad fuse but if fuse is good, then .......... Sorry.
Maytag... | Answered on Aug 31, 2017
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Maytag... | Answered on May 05, 2014
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Maytag... | Answered on Jun 08, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Maytag... | Answered on Aug 07, 2010
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Maytag... | Answered on May 06, 2010
Check underneath M/wave theres a belt it has come off or is slipping.
there wiil be some paint of the in side
Maytag... | Answered on Apr 29, 2010
do not try to fix it yourself !!!!
microwave can hit you with 4200v !!!
you have internal problem that only tec' can help you with :( sorry but your life worth more then the microwave.
Maytag... | Answered on Jan 01, 2010
My research came up with a shorted keypad (shorted key). The part number I came up with was W10258190 this is for stainless. I hope this information helped. Good Luck
Maytag Microwave... | Answered on Dec 21, 2019
Request the diagram from Maytag.
Maytag Microwave... | Answered on Nov 27, 2019
The SE error code means you have a shorting membrane keypad.
you would need to replace either the membrane keypad or the control panel frame assembly, which comes with a new keypad already installed.
unfortunately, those parts for this model seem to be unavailable. So the only option would be if you can find a used or "New Old stock" part on eBay or at a local or online appliance parts store.
If you can find either of these parts, that will fix your microwave:
DE94-01386S ASY CONTROL-PANEL (STL)
DE34-00233N SWITCH MEMBRANE (BLK)
The support page for your microwave is here, where you can find manuals and a helpful exploded view part diagram.
https://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5207BCS&siteCd=WHRCOM&userType=Consumer
Good luck.
Maytag Microwave... | Answered on Jun 30, 2019
Maytag Over-the-Range Microwave Logo
Popular Tags
21 questions posted
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
vent fan wont turn off
  • Microwave Ovens
