20 Most Recent GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Questions & Answers
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
GE 25.0 Cu. Ft.... • Answered on Jun 27, 2012
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
GE 25.0 Cu. Ft.... • Answered on Mar 21, 2011
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
GE 25.0 Cu. Ft.... • Answered on Mar 19, 2011
try to rotate manually defrost timer possible stock up or the thermo disc defective replace it or the dfrost heater busted need technician for replacing this parts conduct observation after.
GE 25.0 Cu. Ft.... • Answered on Mar 05, 2011
A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
Let me know if you have any questions!!
GE 25.0 Cu. Ft.... • Answered on Feb 22, 2011
Your water control valve is stuck open because of defective microswitch in door dispenser. (Behind where you press your glass) or the water control valve that opens when dispenser is pressed is stuck open due to particals of debris caught in the dual water control valve. For example the=> PSS26MGPACC Item 72 in photo or in dual water control valve itself=> Dual Water control Valve
Sea Breeze
All answers does depend on your model number, Click Model Locator here=> GE Model Number Locator Side by Side
Top Freezer
Bottom Freezer
Please let me know if helpful or if you have other questions, Thanks, Sea Breeze
GE 25.0 Cu. Ft.... • Answered on Feb 14, 2011
FIRST YOU MIGHT CHECK THE FREEZER AND HEAR IF FAN IS RUNNING IF IS NOT THAT IS PROBABLY THE CAUSE .
the freezer usually goes through a defrost cycle heres how it works What you probably didn't notice was that the freezer has not been going through it's normal defrost cycle. Because of this un-noticed event going on, there has been frost building up on the evaporator coils that doesn't belong there. After this frost continues to build up over the course of a few days to a week or so, now you are going to start to notice the effects.
Here is what's happening when you have a malfunction in the defrost system.
  • Air cannot circulate from the freezer(where the cold happens basically) to the fresh food section.
  • Your refrigerator will run constantly to try to cool the fresh food section. This will develop a new set of problems with your refrigerator. More on that later....
  • Excess frost builds up within the coils inside the freezer. This is what is blocking the air flow to the fresh food section
  • Usually you will notice the icemaker will stop making ice. Poor air flow and not quite cold enough temperatures in the freezer cause this
  • Water will not come through the dispenser on the door. Cold air settles, the water resovoir will freeze.
  • Compressor may overheat and shut off. This is when you hear, click, click, click. Not good
  • Ice Cream in the Freezer will start to get soft. That's really not that bad. lol
What can you do about this. Let me explain the defrost system in general so you get an understanding of what is going on.
The coils inside the freezer are the only part inside the whole refrigerator that "get cold". They need to stay free from excess frost build up so that air can pass through the coils and reach the refrigerator section of your refrigerator. Every eight hours or so, depending on the type of defrost timer or control you have, the compressor and fans will shut off and the machine will go into defrost modeWhen the refrigerator is in defrost there is a heater that is tied into the evaporator coils inside the freezer that comes on. This heater is behind the rear panel inside the freezer where the evaporator coils are located. It melts the frost that has accumulated over the course of time. After about thirty minutes the machine comes out of defrost and goes back to normal operation.
Now the air can continue to pass through the coils and keep the freezer frozen and the refrigerator cool and everybody is happy.. these are issues that happen when the defrost cycle stops working best thing to do is pull off the rear panel inside the freezer and see if you have any ice build up on the condensor if you do or if the fan is not running then you would have a defrost problem and I could tell you how to go about checking which part of the defrost cycle was problematic also message me back your model number and i will be able to send you schematics on your machine as well you can either wait to remove the rear panel till i send your diagram or you can remove it and message me back with your finds on if there is any ice build up and if your fan in back of that same panel is working you said that your temp in fridge is 38 if the fan wasnt working it would just get warm in frige but be cold in freezer and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to help others in the future with similar situations Thanks again Rick
GE 25.0 Cu. Ft.... • Answered on Feb 06, 2011
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
GE 25.0 Cu. Ft.... • Answered on Feb 01, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
GE 25.0 Cu. Ft.... • Answered on Jan 30, 2011
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
GE 25.0 Cu. Ft.... • Answered on Jan 17, 2011
heatman101
GE 25.0 Cu. Ft.... • Answered on Dec 27, 2010
Is there frost on the back panel of freezer?need more info.
GE 25.0 Cu. Ft.... • Answered on Dec 23, 2010
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
94 questions posted
Top Refrigerators Experts
Vish Iyer
Vish Iyer
gbob59
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
freezer refrigerator maintain good
  • Refrigerators
