Hello, bonnie
I was trying to help you out here. Maybe this will help some? I was going back to
some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them,
So, I thought I would take some of my personal time to see if I can help. Even
though this Informational site may not have your exact model or brand, this
site will help you a lot. Here is a site
link about everything you want to know
about ovens and possibly yours, fromrepairto
trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written
would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other
problems you might have in Automotive, Appliance, and Electronics. Drop In
anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Hello, Katharine
Thanks, Mike
Hello, ante
Thanks, Mike
Hello, FrancisI was trying to help you out here. Maybe this will help some? I was going back tosome customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them,So, I thought I would take some of my personal time to see if I can help. Eventhough this Informational site may not have your exact model or brand, thissite will help you a lot. Here is a sitelink about everything you want to knowabout ovens and possibly yours, from repairtotrouble shooting it. http://home.howstuffworks.com/how-to-repair-an-oven.htmPlease if this helped you at all, if you can find the time and in your heart to rate my help and some kind words writtenwould be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for otherproblems you might have in Automotive, Appliance, and Electronics. Drop Inanytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
Hello, bamI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>http://home.howstuffworks.com/dishwasher.htmPlease if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mikehttp://home.howstuffworks.com/how-to-repair-an-oven.htmPlease if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help Thanks, Mikehttp://beta.fixya.com/users/mc1bean
Please confirm that the oven is getting the correct voltage. ( most likely 220vac across the two hots or 115 from a hot to ground ). If that turns out OK...Please check to make sure that the thermocouple is not in direct contact with a heating element. It needs to float in the space of the oven not touching anything. Hint that thermoc. looks like closed end 1/8" pipe.
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
There are two types and they both work to a theme. Modern Oven hinges are inset into the door itself, so you just split the door apart, take the old ones out and the new ones in. The other type have the hinges inside the oven itself between the outside of the oven cavity and the outer panel. With those you pull out or remove the wall oven and look at the back and underneath for the screws. Remove the side panels, remove and replace the hinges.
Door Mounted Hinge
Side Mounted hinge
your Maytag range has only a single heating element located at the top of the oven, it is likely a "broil" element, which is used primarily for cooking food close to the top of the oven. The lower heating element, which is typically used for baking and roasting, may be hidden beneath the oven floor or located at the bottom of the oven.
If your oven is not getting very hot, it is possible that the broil element is malfunctioning and needs to be replaced. However, if the oven is not heating evenly or is not getting hot enough to cook food properly, it may be a more complex issue related to the temperature sensor, the control board, or other components.
To diagnose and repair the issue, it is recommended to have the range serviced by a qualified technician, who can properly identify the model and locate the faulty component. The model number of your range can typically be found on a label inside the oven door, on the back of the range, or on a storage drawer beneath the oven.
Check the voltage to the oven. Also, check the contacts on the oven relay. (If the relay shows signs of having been overheated, the contacts are probably bad, but not every bad contact will cause visible overheat damage.)
Inspect all of the connection terminals in the wiring from the inlet power to the controller relay to the heating elements. A poor connection will overheat the wire but prevent proper heating of the element. Heavily oxidized or loose terminals should either be cleaned up or replaced. Since you say both elements have the problem, I would start first with the input power connection. That includes turning off the breaker to the oven and checking the wall socket.
If you have aluminum wiring to the wall socket, the connection may need to be redone. First verify that the socket is marked for aluminum wiring (Al or Al/Cu). Aluminum wire connection requires great care: the wire must be cleaned to expose shiny metal, then immediately coated with a special grease made for aluminum wiring before insertion into the socket terminals, and the terminals must be torqued to specification. Otherwise, you will eventually have a poor connection and possible fire hazard. If you don't see any grease on aluminum wire, that could be the problem. If you have copper wire, standard wiring procedures apply.
To change: Press and hold BROIL for 5 seconds. A tone will sound, and "°C" or "°F" will appear on the display. Repeat to change back.I think the oven must be working to do it, otherwise contact the manufacturer for advice.
