20 Most Recent Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Questions & Answers
Convert them to a format that is supported - jpg. If there are already jpg then resize them.
Kodak EasyShare... | Answered on Jul 12, 2010
Make sure that your songs are in MP3 format. It should have a file extension of .mp3 as the frame can only support that file format when it comes to music.
Kodak EasyShare... | Answered on Jan 13, 2010
simply a format thing, you'll have to adjust your camera to take pics in the correct format, one your photo frame can support.
Kodak EasyShare... | Answered on Jan 11, 2010
Make sure you have installed the Kodak digital display Software then you can just drag and drop the pic to your pc or vice versa
Kodak EasyShare... | Answered on Jan 08, 2010
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I highly advise not to forcedly take it out of the frame as it may damage some parts of the frame.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Kodak EasyShare... | Answered on Jan 04, 2010
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Follow the steps bellow to resolve this issue:
1) right click on the kodak icon on your desktop
2) left click on properties then click on the compatibility tab
3) uncheck all the boxes the hit apply then ok the keep the changes
4) also try checking if the program was just minimized on your taskbar
Kodak EasyShare... | Answered on Dec 30, 2009
Ok, look for a stick of broom or any other thing that is as tiny as a broom, insert it into the card slot and look for a way to bring the card out with it.
Or maybe you should loose the cover of the easyshare m820/m1020 so that it would be easy for you to access the internal part and it would me more easier for you to remove the card.
Take care.
Kodak EasyShare... | Answered on Dec 28, 2009
try using a different converter software. Usualy dvd's without div X have problems with AVI. but try converting them to WMA
Kodak EasyShare... | Answered on Mar 30, 2009
To the best of my knowledge all 35mm cameras load identically, apart from a few automatic models that claimed to be self loading.
A new film cassette has a tongue of film protruding. Once the cassette has been loaded into the recess on the left and the rewind crank pushed down and engaged with the film spool, a couple of inches of film is pulled from the cassette and the tongue poked through the slot in the takeup spool - it might be necessary to use the film advance until the slot is visible.
With about a half-inch of film pushed through the slot, slowly advance the film until the slackness is gone while fully engaging the sprocket holes at the edges of the film on the teeth of the sprockets. Advance the film a little more to check it is properly engaged and once you are satisfied close the camera back firmly making certain the catch is engaged and it won't spring open again.
Once closed, advance the film until it stops which signals the shutter is set and is ready to take a photograph, however the first and perhaps the second frame has been contaminated with light and so press the shutter release, advance and press again and the third advance is where the photographs begin. If there is a frame counter it is best to be guided by this.
Cameras that have a manual advance usually have a manual return crank that will be seen to rotate as the film is advanced. When all the frames have been used the film will be felt to come to the end. At this point the clutch button must be pressed to disengage the wind-on mechanism and the film wound back into the cassette using the crank on the left.
Kodak... | Answered on Sep 30, 2020
Again, most kind of you to pass on this information. Was there any particular reason behind your doing so ?
Kodak... | Answered on Aug 24, 2017
Kodak EasyShare 8" LCD Wi-Fi Digital Photo Frame Logo
17 questions posted
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
View Most Popular
Kodak Photography
  • Kodak Photography
Most Popular Question
kodak photos not showing full screen in
  • Photography
