20 Most Recent Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Questions & Answers
I have a model MFI2568AES and had to purchas power
you have the wrong board,when ordering the new board you need the model and serial numbers.you need to put in your model number and then add the first two digits off of serial number to get the correct board so it will take your code,say the first two digits are 12 then you need to see what board is for MFI2568AES12 YOU PROBABLY HAVE BOARD PART WP12920710 BUT FOR YOUR MODEL AND SERIAL YOU NEED PART WPW10310240 and then you'll be able to enter your code
1/7/2018 10:54:33 PM • Maytag Ice2O... • Answered on Jan 07, 2018
The door open alarm is going off but there is no door open what can I do for this problem
check the door switch possible bad
9/5/2017 1:45:05 AM • Maytag Ice2O... • Answered on Sep 05, 2017
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5/11/2014 2:31:09 PM • Maytag Ice2O... • Answered on May 11, 2014
Remove icemaker
Mine does that. Ice is frozen to the drive shaft. Try using a long thin flat blade screwdriver under the ice bucket to try and lightly pry the bucket off. If it won't still budge then try removing all the ice you can and then running a hair dryer pointed at the bottom of the ice bucket where the metal part is. This will help melt the ice build up in there. 2nd option is pouring hot water in the bucket. This is all going to make a huge mess on the floor so get some towels. Eventually it will lift off while pushing the button in. The actual latches are plastic and not very long. It's the ice that's keeping it from lifting off.
10/19/2013 6:29:00 AM • Maytag Ice2O... • Answered on Oct 19, 2013
Control lights are flashing and
This is a very common issue and it means that your high voltage control board on the back of the refrigerator has shorted and will need to be ordered and replaced.You could buy the board from any of the local appliance store or online from many sites such as repairclinic.com
The cost of the part would be around $175 - $200.
Thanks and Regards
taran_2005
4/8/2011 11:41:50 AM • Maytag Ice2O... • Answered on Apr 08, 2011
2answers
How is the ice maker removed to install a new one
An ice maker is a electrical unit that is installed into a freezer.
Water flows into the icemaker through a tube on the back of the refrigerator. The water is then transformed into ice by the ice maker, allowing you to enjoy a nicely chilled beverage.
Installing and removing an Ice Maker is very easy. The process may vary slightly depending on the model of refrigerator, but the technique will be similar.
Instructions
Things You'll Need:
  • Screwdriver
  1. Ensure that the water going into the ice maker is shut off. If there is not a valve on the water line going to the refrigerator, check under the house, because there is usually a shutoff valve there.
    If there is no shutoff valve for the water line, which is rare, it is possible to cap off the water line with a screw on end cap. If this is the case, you would have to shut the water off completely in the house, cap off the water line, and turn the water back on.
  2. Remove the container that holds the ice, as well as any plastic shelves.
  3. Remove the screws holding the ice maker in place. There are usually only two and they connect the icemaker to the inside of the freezer.
  4. Disconnect the wiring harness that is hooked up to the ice maker.
  5. Disconnect the water line from the ice maker.
  6. Remove the ice maker.
Thanks.
1/3/2011 2:26:07 PM • Maytag Ice2O... • Answered on Jan 03, 2011
0answers
My refrig stop making ice after I changed the
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
5/28/2010 10:33:54 PM • Maytag Ice2O... • Answered on May 28, 2010
How do i set controls on mod # mf12569vem french double door refr
Just had this problem...replace the filter or insert the bypass valve.
Also the model # is MVI2569VEM....(not a 1 but an I) if you replace the 1 with an I you will get the manual at maytag.com
Here is a link.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/User%20Instructions%20-%2012828186A.pdf
5/21/2010 2:16:22 AM • Maytag Ice2O... • Answered on May 21, 2010
I want to remove the icemaker to dislodge an ice blockage
OK I will waste no time on this on. I believe the dual water control valve is responsible and has been leaking water to ice maker even while valve is off. Click Here=> MaytagIce2oRefrigerator Service Manual Dual water control valve part Click here=> 67006322 or here=> GE ARTICA PROFILE TECHNICAL INFORMATION Scroll down and will be the fifth photo on left. If you have any questions please let me know. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
4/25/2010 3:04:57 AM • Maytag Ice2O... • Answered on Apr 25, 2010
My maytag frig with the freezer on the bottom has
Good day,
Just follow this step by step proceedure. It'll get you there.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
3/8/2010 2:48:46 PM • Maytag Ice2O... • Answered on Mar 08, 2010
I have a Kenmore Elite Refrigerator with freezer
what light flashes? if its the filter light change filter
2/12/2010 2:23:50 AM • Maytag Ice2O... • Answered on Feb 12, 2010
Bottom of freezer in the side by side builds up
We have a defrosst drain problem we will need to work on, WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home. Or this sounds like you have a blockage in the drain tube, remove panel back of freezer...you may see ice build-up, melt ice with hair dryer, you will see a pan below evaporator, melt ice in pan, dry water up in pan with towel, now you should see drain hole in pan that leads to drain tube, pour some hot water in pan, wait a couple minutes, wipe up water and repeat this step 2-3 times, once you have done this use a wet and dry vacuum cleaner to vacuum out the gunk or blockage in the drain line. Now it is cleaned out! Put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. Good luck! PS Please don't forget to rate my solution Thanks! Sea Breeze
2/6/2010 6:39:25 PM • Maytag Ice2O... • Answered on Feb 06, 2010
Why is the ice maker and water dispensing panel on
I called a repair man to fix this problem - "FixYa" was absolutely useless in this case. Turns out there was a short on the control board and it needed to be replaced.
12/4/2009 3:10:03 PM • Maytag Ice2O... • Answered on Dec 04, 2009
Ice Maker
move arm to down postion. defrost and clean ice maker, ice jam
9/8/2009 1:52:26 AM • Maytag Ice2O... • Answered on Sep 08, 2009
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem     If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
5/5/2009 2:37:53 AM • Maytag Ice2O... • Answered on May 05, 2009
Maytag Ice2O 24.9 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
Popular Tags
32 questions posted
Top Maytag Refrigerators Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
vince
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
control lights flashing
  • Refrigerators
