20 Most Recent Olympus Zuiko 70-300mm f/4-5.6 Digital ED Telephoto Zoom Lens for Select Cameras Questions & Answers
Problem useing the zoom on Olympus 70-300mm Lense
No, but it appears that there is a bad tooth or something in the gear mechanism of the lens. Internal issue, hopefully over time it will "go away." Cross fingers and hope it does not get any worse. I would carefully shake the heck out of it to possibly dislodge what ever it is.
9/3/2017 2:55:00 PM • Olympus Zuiko... • Answered on Sep 03, 2017
0answers
I have a 70-300 mm for my E-520. It is barely a
The lens is definitely faulty. Either return it to the retailer for an exchange/refund or send it to the manufacturer for a warranty repair. Of the options available, a warranty repair should be your absolute last choice.
9/30/2010 11:04:12 PM • Olympus Zuiko... • Answered on Sep 30, 2010
Will the Zuiko 70 - 300mm f/4-5.6 ED lense fit my
Yes, no problem at all. The lens is a Four-Thirds mount and that's what your camera is designed to accept.
Please take a moment to rate my reply and feel free to add a comment if there's anything in my answer which has left you with any further questions.
9/15/2010 10:26:34 PM • Olympus Zuiko... • Answered on Sep 15, 2010
The manual focus seems not to be continuous, as
What kind of device are we talking about here? Actually, it doesn't matter, since this type of problem almost always requires servicing. Servicing or buying a new camera is always a process you have to make the call on. Get an estimate from a camera shop, and go from there.
3/10/2010 6:26:00 AM • Olympus Zuiko... • Answered on Mar 10, 2010
I have the 70-300mm and for some reason i cant get
Quick temperature changes may cause this. I have the same lens. May be you must clean the pins while attaching lens to the body. If this information will help you please give your vote. Good Luck.
2/24/2010 11:54:57 AM • Olympus Zuiko... • Answered on Feb 24, 2010
Zuiko 70-300mm lens focusing problem
Haha!!
Maybe its something you're not doing, LOL.
Look on the side of the lens. Most of the 70-300 macros have a slide switch. My Tamron, for instance, needs to be zoomed out to 300, then slide the switch to Macro and its ok. Look for the slide switch. You might also notice lines of a different color to denote Macro.
Some days it too tough to be smarter than the lens,
LOL.
1/3/2010 2:56:40 AM • Olympus Zuiko... • Answered on Jan 03, 2010
Zuiko 70-300 evolt 300 malfuntion at start up
You MUST update you firmware on the E300 and if using XP take out the memory card.Go to Olympus master online.
6/16/2009 7:26:10 AM • Olympus Zuiko... • Answered on Jun 16, 2009
Blurred Images with Olympus E520
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
3/24/2009 2:57:07 PM • Olympus Zuiko... • Answered on Mar 24, 2009
Olympus Zuiko 70-300mm lens focus question
Solved
3/16/2009 9:31:33 PM • Olympus Zuiko... • Answered on Mar 16, 2009
Zuiko 70-300mm
I spoke to our local J&A Camera shop who gave me a short tuition on the lens.
Most of this I was aware of.
Thank you to J&A and yourselves.
Malc
11/26/2008 3:51:03 AM • Olympus Zuiko... • Answered on Nov 26, 2008
My Olympus C-4000 zoom will not boot to my imac
Did it do it before? It needs Software and Drivers, it may also need Firmware for your iOS version. I am having difficulty bringing up software for it, even where it is linked. https://www.google.com/search?q=olympus+c+4000+imac+software ./..
10/15/2021 9:39:30 PM • Olympus Cameras • Answered 2 days ago
I had to by a new memory card to my Olympus Camedia C 750. I just found out that the 1GB I bought, will not work. Is tere any way of make a partion to make the camera accept the card?
Is the card you bought compatible with your camera? Older cameras cannot work with newer versions of memory cards. SD, SDHC,SDXC etc. have different form factors and old model cameras are not compatible with newer versions. If the problem is related to the card, you might like to re-format the card from a computer before inserting it in the camera and then format it again from the camera. Check and verify that before you try other solutions.
7/7/2021 3:45:25 AM • Olympus Cameras • Answered on Jul 07, 2021
My Olympus SP-560UZ shows "battery empty" with new standard (non-rechargeable) batteries. Solutio requested please.
go buy a new battery pack we will not do it for you
5/31/2021 9:32:45 AM • Olympus Cameras • Answered on May 31, 2021
Olympus OM-2 spot/program battery problem: the batteries drain in a couple of shots.
I had a similar issue with an Olympus OM4. It went in for repair but was never resolved. The batteries in my OM1-md last forever! I ended up doing the same remove the batteries after use. I can't remember the configuration, but if the LR44 are two and double stacked, you could use the Lithium equivalent. https://www.batteryequivalents.com/ag13-sg13-lr1154-sr44-303-357-a76-lr44-battery-equivalents.html ..
2/1/2021 12:48:55 AM • Olympus Cameras • Answered on Feb 01, 2021
Where I can find Manual for OLYMPUS ACCURA zoom XB70 camera
Olympus would be a possible source.
11/6/2020 7:59:54 AM • Olympus Cameras • Answered on Nov 06, 2020
Can I get rid of 3c81 error code on my Olympus E-1?
Have you tried using Google to find out what the error code actually means ? Very often, the first step in defining and correcting an error is to find out what has caused it.
6/25/2020 10:31:31 AM • Olympus Cameras • Answered on Jun 25, 2020
3answers
Which camera do you recommend - FujiFilm, Olympus or Sony?
I would recommend Sony for a best film or picture.
6/15/2020 8:46:23 PM • Olympus Cameras • Answered on Jun 15, 2020
Olympus Zuiko 70-300mm f/4-5.6 Digital ED Telephoto Zoom Lens for Select  Cameras Logo
Popular Tags
20 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
70 300 mm e 520 barely
  • Cameras
