20 Most Recent Kaz Sesame Street Elmo & Friends Humidifier - Blue Questions & Answers
Make sure you soak the wic with COLD water and don't ring it out. Make sure when your putting the tank back in that you don't spill any water into the fan vent. If you get even a splash into the vent, it makes that awful loud motor noise. If this happens just let it dry out on it's own(over night). Also try cleaning the wic tray. It tends to get slimmy from the water sitting in it. If you ever see that your tank is empty, wet your wic when you refill it. Make sure you rinse and wet the wic EVERYTIME you refill the tank. The wic dries out fast and can start smelling pretty bad if you don't rine it regularly.
Kaz Sesame... | Answered on Jan 08, 2014
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Kaz Sesame... | Answered on Apr 19, 2011
yes its normal thay have it in many collor White, Blue, Pink, Orange, Green, Yellow, Turquoise and Purple.
Kaz Sesame... | Answered on Jan 31, 2009
Google (kaz)(76)(manual) without parens OR contact Kaz directly to request.
Kaz Humidifiers | Answered on Aug 26, 2019
Steam generating elements defective
Kaz Humidifiers | Answered on Jul 26, 2018
Request specifications for model 101directly from Kaz.
Kaz Humidifiers | Answered on Jan 07, 2018
Kaz Sesame Street Elmo & Friends Humidifier - Blue Logo
10 questions posted
Top Kaz Humidifiers Experts
ray gallant
Tom Chichester
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Kaz Humidifiers
  • Kaz Humidifiers
Most Popular Question
clean
  • Humidifiers
