20 Most Recent
PNY Optima High-Speed 512MB Secure Digital Memory Card Questions & Answers
How do i format a sdhc
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Printer will not read card
Try to use your card in a clean computer and run a virus or malware test on it. Make sure that the card has no unwanted hidden folders that may contain virus files unblocking the card from being accessed by your printer.
I bought a PNY 16GB USB Flash Drive to download my music to, but it doesn't DO anything... I am using Windows !0. When I plugged it in nothing happened. Please, I have been trying for hours, HELP!
The flash drive may need to be REFORMATTED. In some cases, the flash drive is pulled out from the USB port incorrectly. That can lead to a damaged Flash Drive.
Always remove Flash Drives by using the EJECT method.
To format the USB Flash drive, go to the File Explorer (the bottom row of Icons on the computer screen showing a manila folder inside a holder) and locate the USB drive by letter, such as drive B,C,D, etc. One of these letters or higher. Tap the corresponding to the USB drive and an option box comes up. Select "Format" (Quick is ok). Once formatted, the drive is ready to accept data once again. If it cannot be formatted, then the USB DRIVE may have sustained damage to the circuit and no longer can be of service.
How do I close a PNY 16 GB flash drive?
You don't really close it, you just tell the computer to turn it off so you can safely remove it, thats what the "Safely remove drive" option on windows does. Go to it and select the drive you want to remove, it will do the rest.
Does PNY DDR3 work in HP Pavilion C6537c-b?
Consider downloading a manual for you model for the answer.
what type was in it before? IT wil require the same type but it has space limitations.
www8.hp.com/us/en/home.html
