20 Most Recent Nostalgia Electrics Hot Dog Grill Roller with Griddle Questions & Answers
Then you are stuck with it, either that or you search for a replacement receptacle online & then take it back
Nostalgia... | Answered on Nov 11, 2014
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Nostalgia... | Answered on Oct 27, 2011
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
heatman101
Nostalgia... | Answered on Apr 29, 2010
Experiment with it. Start with just a little oil and periodically add more until it flows properly. Be sure it sets up when it gets cool, if it doesn't you have to much oil.
Good Luck,
Gilshultz
Nostalgia... | Answered on Dec 03, 2009
You should be able to select 12h or 24h when setting time.
Nostalgia... | Answered on Mar 20, 2018
I found your owner's manual here: http://nostalgiaelectrics.com/?wpfb_dl=155 Took a fast look through it and found no reset switch. However, there is an automatic lock. Just hit the cancel button and within 2 minutes, use your unit.
Nostalgia... | Answered on Feb 03, 2018
Water line may be frozen, heat it with a hair dryer, see if water then flows.This can happen if aair flow to bottom of frig is blocked.
Nostalgia... | Answered on May 14, 2017
Nostalgia Electrics Hot Dog Grill Roller with Griddle Logo
15 questions posted
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Anthony Ward
Anthony Ward
Sheldon Dedek
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Kitchen Appliances - Others
Most Popular Question
instructions hot dog roller
  • Kitchen Appliances - Others
