20 Most Recent Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray Questions & Answers
2answers
Samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
1/4/2020 1:51:33 PM • Samsung Wireless... • Answered on Jan 04, 2020
0answers
2answers
Samsung Glyde security lock code.
slide open and dial #43574357* and tap system info and the code is the last four digits of the "MDN".
5/17/2010 12:34:38 PM • Samsung Wireless... • Answered on May 17, 2010
Bluetooth bbx-01 code
try 0000 (4 Zeros) if that doesn't work try one of these:
1111, 1234, 9999
5/6/2010 7:44:01 PM • Samsung Wireless... • Answered on May 06, 2010
2answers
Wep500
0000 is the default pin.
3/10/2010 9:42:07 PM • Samsung Wireless... • Answered on Mar 10, 2010
Samsung Glyde switched to nam2
Follows these simple instructions and ur phone will be unlocked in no time! AT HOME SCREEN, SLIDE OPEN, TYPE IN (#43574357*), TAP SYSTEM INFO, THE CODE IS THE LAST FOR DIGITS OF THE "MDN".
7/18/2009 9:36:16 PM • Samsung Wireless... • Answered on Jul 18, 2009
3answers
Install bluetooth
utstatcome does not have bluetooth that trasfer data it only support the headset
7/13/2009 5:20:13 AM • Samsung Wireless... • Answered on Jul 13, 2009
I buy a cell telephone samsung
it will tell you under settings then connection.
7/11/2009 1:24:25 AM • Samsung Wireless... • Answered on Jul 11, 2009
Connect to phone
Well... i think you need to specify a little. just write down if its bluetooth or if its some other connections...
4/24/2009 9:42:09 AM • Samsung Wireless... • Answered on Apr 24, 2009
I have a bluetooth from samnsung and tryin to pair
I took my bluetooth and phone to a Sprint store and the representative was able to pair it for me. Thank you and have a good day.
4/20/2009 4:02:29 PM • Samsung Wireless... • Answered on Apr 20, 2009
How to pair moto 700 with samsung delve
moto -700s the vain of my existance. my experiance with this troublesome unit is with the boom mike closed hold call button down till light turns purple, quickly pull mike down and while still purple ( thats discovery mode) pair it with phone and if it askes for a pass key its 0000 ,and 1234 is backup key code. hope you only have 1 of these. i have 7. but they sure are pretty huh? good luck
1/26/2009 9:34:00 AM • Samsung Wireless... • Answered on Jan 26, 2009
2answers
Need a users manual for my wep 500
Here is where you can go to download a copy of the WEP 500 Quick Start Guide. Hope this helps.
http://support.sprint.com/resources%5CSamsung_WEP500_Pairing_Guide.pdf?z=z&navtypeid=1&pagetypeid=7&prevPageIndex=9&lid=y
8/10/2008 1:00:16 PM • Samsung Wireless... • Answered on Aug 10, 2008
MY LG TONE HBS-730 stuck on incorrect pin i have samsung mobile
Here are some steps you can try: Reset the Headset: Turn off the headset. Press and hold the REW (rewind) button and the PLAY/PAUSE/STOP button simultaneously for about 5 seconds until the LED indicator flashes purple. The headset will reset, and you can try pairing it again. Pairing with Samsung Mobile: Make sure your Samsung mobile's Bluetooth is turned on. Slide the power switch on the LG HBS-730 to the "ON" position. The LED indicator on the headset will be solid blue, indicating it's in pairing mode. On your Samsung mobile, go to the Bluetooth settings and search for new devices. Select "LG HBS-730" from the list of devices. If prompted for a passcode, enter "0000" (four zeros). Once paired, you'll hear "Your headset paired." Check Battery Level: Press and hold the VOLUME DOWN button for 1 second to check the battery status. The audible alert will indicate the battery level (high, medium, or low). Charge the Headset: Connect the charger to the headset. While charging, the LED indicator will show a solid red light. When charging is complete, the LED indicator will turn off. Remember that the headset will automatically turn off if not paired within 3 minutes. If these steps don't resolve the issue, refer to the HBS-730 User Manual for more detailed instructions.
4/20/2024 10:44:15 PM • Samsung Radio... • Answered on Apr 20, 2024
Remote control for my vr headset will not sync up with my samsung ace phone
Both volumes buttons should be press at the same time and check out all settings before starting a https://mybestvrheadset.com/how-to-make-a-vr-headset-without-lenses
5/5/2021 7:05:05 PM • Samsung Radio... • Answered on May 05, 2021
2answers
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
11/18/2019 10:42:38 AM • Samsung Radio... • Answered on Nov 18, 2019
How to program a Samsung tv remote AK59-00149A
https://www.manualslib.com/download/436713/Samsung-Bd-F5100.html From above link down load manual and see instructions on page 13 of this manual, it will solve your problrm.
5/13/2019 7:46:09 AM • Samsung Radio... • Answered on May 13, 2019
Samsung Wireless Headset for Bluetooth-Enabled Cell Phones - Gray Logo
Popular Tags
26 questions posted
Top Samsung Radio Communications Experts
ZJ Limited
ZJ Limited
Jean Thiebaux
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Radio Communications
Most Popular Question
samsung glyde security lock code
  • Radio Communications
