20 Most Recent Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Questions & Answers
2answers
I have a Maytag Gemini Double Oven Range. The
turn off breaker or unplug. then wires commonly burn out near the heating element. To determine if a wire has burned out, inspect the wires leading to the element. If a wire is burned out, it will often be visibly burnt.
1/14/2018 6:02:59 PM • Maytag Gemini... • Answered on Jan 14, 2018
0answers
2answers
I have a maytag gemini stove. If you set the
you may need a bake ignitor
4/6/2016 1:21:23 PM • Maytag Gemini... • Answered on Apr 06, 2016
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
1/3/2015 1:22:16 AM • Maytag Gemini... • Answered on Jan 03, 2015
Still getting an error code F1-1 on top oven after repair man replaced Probe sensor on bottom oven. What do I do now?
Hi, Can I get more information as to the model number of this unit. I would like to research this and understand why the probe was the issue and why another one needs to be replaced. Do you get the same code when the probe is disconnected? I know there was issue with the probe at one time but I haven't seen this in a long time as most people rarely use it. Get back to me and I will see what I can locate for you. Thanks I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
11/23/2014 6:46:03 PM • Maytag Gemini... • Answered on Nov 23, 2014
Repair man fixed top oven probe sensor due to a F1-1 error code. Top oven is still giving the same error code. Repairman wants to come back and charge 200.00 bucks again to replace bottom oven sensor.
The electronic control could have a bad touch pad that is causing this. You may need to replace the electronic control itelf. It is expensive almost 400.00 dollars.
11/22/2014 1:32:58 PM • Maytag Gemini... • Answered on Nov 22, 2014
Why did my maytag gemini double oven coil caught on fire and break in half?
Because it failed Ask an appliance parts store how many times they see that
7/18/2014 2:07:10 AM • Maytag Gemini... • Answered on Jul 18, 2014
Maytag Stuck on "Delay"
You are in the Tiller and Cultivator section of FIXYA but have you tried unplugging or shutting off the Breaker for a few seconds and let the Oven 'reboot'? Ahh, what ever happened to the simple good old fashioned Ovens?
1/22/2014 9:36:05 PM • Maytag Gemini... • Answered on Jan 22, 2014
Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
Popular Tags
153 questions posted
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Marvin
Marvin
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
still getting error code f1 1 top oven
  • Kitchen Ranges
