20 Most Recent
Dynex Stereo Headset with Removable Boom Microphone Questions & Answers
My Dynex headset with removable microphone does
Hello
Usually on default the microphone is not enabled in windows, so you have to do it manually. This is the steps you have to follow.
Control panel
Sound
Recording(or microphone heading, it may differ)
Enable microphone
Now it should work if it was not enabled in the first place.
If this does not work try plugging in the combo in the back panel of your case. or visa versa.
I hope this can help you. Please rate this.
Best regards
The sound is distant?
Plug the USB connector into an available USB port.• Check your computer's volume level.• Check if your computer's volume is muted.• Check your operating system's audio input and output settings.• Check the headset's volume and mute settings.• Restart computer.
When I try to use
What is the model of your Dynex Headset? Please try to plug it into another USB port. Also, as part of the troubleshooting, try to use it into another computer. If it works, please take note of the operating system version.
Try to download also the driver from the manufacturer's website. Make sure though that you select the correct operating system to avoid conflicts.
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
21 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
