20 Most Recent
Mad Dog Multimedia MD-16XDVD9-EXT DVD±RW Dual Layer Burner Questions & Answers
Out of Range
Sounds like your screen saver is on a setting that your monitor will not display. Go to display settings and change everything to a default level such as 1024x768 at 60hz refresh rate. If your monitor is a wide screen it should work with 60hz refresh rate if not it should work at 60,70, or 80 hz. You should also check you power settings for hibernate and sleep modes to make sure they are set to a default display setting.
3/9/2010 9:16:35 AM •
Mad Dog...
Answered
on Mar 09, 2010
I need to get it out of the external case so I can
the only cleaning required on this is the laser reader bulb, to do this u just buy a CD/DVD cleaning kit from any store that has DVD players, walmart has these kits, the kit is just a disc with a brush that u load like any DVD, then follow the on screen instrutions..
11/22/2009 10:20:13 PM •
Mad Dog...
Answered
on Nov 22, 2009
I had Nero 6 Suite preinstalled on my computer
Anyway you don't have actually the nero installation disc provided with buying cd/dvd drive.
All you have to do is aside from Nero, there's a lot of burner programs which you can use in the internet like for example: Ashampoo Burning Studio, ImToo, Roxio, & etc..
And this are all you can download at their websites.
Here are the link.
www.ashampoo.comGood luck!
10/9/2009 12:27:55 AM •
Mad Dog...
Answered
on Oct 09, 2009
Phone number
check with the manufacturer of the device, mad dog does not make any devices, they just repackage other companies devices
9/22/2008 12:32:03 PM •
Mad Dog...
Answered
on Sep 22, 2008
MD16XDvd (
mad dog does not make there own hardware.
check the label on the drive to see who manufactured it, then go to their website & download the latest drivers & firmware
9/22/2008 12:30:32 PM •
Mad Dog...
Answered
on Sep 22, 2008
Will not read on my labtop
It is broken. Either replace it,
or purchase an external CD/DVD reader/writer, with a USB interface.
4/23/2015 4:03:00 PM •
Mad Dog...
Answered
on Apr 23, 2015
Where do i fine the model number
The model number will be on a tag on the driver. You can also see it under storage devices in menu once installed..
10/11/2012 7:40:28 PM •
Mad Dog...
Answered
on Oct 11, 2012
Does not rcognize a dndr
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
9/6/2011 4:48:57 AM •
Mad Dog...
Answered
on Sep 06, 2011
When I try to burn
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
3/25/2011 12:49:22 PM •
Mad Dog...
Answered
on Mar 25, 2011
