20 Most Recent
Mad Dog Multimedia Dominator 4 in 1 (MD-5216CDR) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
I need a cord for the mad dog multi media device
What device do you need a cord for? The Mad Dog Dominator given above is an internal IDE CD/DVD drive. Thus it can be connected to a 4 pin peripheral molex connector to the power supply and a 40 pin IDE ribbon cable. Some USB/SATA/IDE devices will be able to connect to the drive for external use (since it is a full size 5 1/4" drive). Similarly, you can find some USB external device enclosures that will work with the IDE connect.
There are IDE to SATA converters that you can add to connect the drive to a computer with no IDE port on the motherboard. (There are also power adapters to convert a SATA power connector to the 4 pin in the rare case that you do not have a free 4 pin connector. However, a 4-pin y-connector is usually a better choice).
All of the above items are available from most computer supply shops.
I wish that I could be of more help.
(external hard drives currently can have one or more of the following connectors: USB 2.0, e-SATA, Firewire, ethernet, or USB 3.0. The USB 2.0 is the most common. A standard USB cable (A/B) is the usual one for a USB 2.0. These are also available at most computer shops. Look at the device and the size of the opening to determine the cable end needed. Standard B is a square end with beveled corners. Usually a text or icon on the device will indicate the port type.)
10/21/2010 5:15:21 PM •
Mad Dog...
Answered
on Oct 21, 2010
Will not read on my labtop
It is broken. Either replace it,
or purchase an external CD/DVD reader/writer, with a USB interface.
4/23/2015 4:03:00 PM •
Mad Dog...
Answered
on Apr 23, 2015
Where do i fine the model number
The model number will be on a tag on the driver. You can also see it under storage devices in menu once installed..
10/11/2012 7:40:28 PM •
Mad Dog...
Answered
on Oct 11, 2012
Does not rcognize a dndr
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
9/6/2011 4:48:57 AM •
Mad Dog...
Answered
on Sep 06, 2011
When I try to burn
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
3/25/2011 12:49:22 PM •
Mad Dog...
Answered
on Mar 25, 2011
I am trying to burn
the cd/dvd burner might not be getting enough power
make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty or just replace them include electrical extension leads
or you might have bad batch of rewritable cd/dvd's
hope this helps
11/12/2010 12:42:26 AM •
Mad Dog...
Answered
on Nov 12, 2010
I put a floppy disk
Have you tried another disc?
If you have a spare disc and after formatting, you fill it with data,
check the output. If it's read, then the problem is with your original disc.
9/1/2010 11:20:13 AM •
Mad Dog...
Answered
on Sep 01, 2010
Cw5205 will not install in my hp xp
Windows updates should fix it.
Go to START, PROGRAM, WINDOWS UPDATE do all the updates, look for any hardware updates available in the left column, if you see any go ahead and install it then rebooth your computer. Make sure you have installed Windows XP service pack 1, sp2 & sp3
12/19/2009 11:59:12 PM •
Mad Dog...
Answered
on Dec 19, 2009
I have a Mad Dog hard drive enclosure that I did
It would cost just as much to purchase a "SERILLEL" adapter as it would cost to purchase another "empty" external hard-drive case that has support for the newer-style 'SATA' hard-drive.
If you have a newer desktop-computer, you probably have an unused SATA port on your motherboard, and an unused SATA power-connector. Temporarily connect the SATA drive to your motherboard, and do the recovery.
10/26/2009 3:23:46 PM •
Mad Dog...
Answered
on Oct 26, 2009
Dvdr cannot find dvd disk
tonkatl2 --
If the DVD drive had recognized disks before, but is unable to now, more than likely (95% chance) your optics are dirty... try using a cotton swab with a LIGHT amount of rubbing alcohol, "rolling" GENTLY across the lens while rotating the swab in the opposite direction you are cleaning... should do the trick :) Also, use the other end of the swab to clean around the tray itself (try avoid using an aerosol can/spray, as this will just blow dust into the unit, which just prolongs the inevitable "dust on the lens" issue.
If this doesn't work, please post a comment to this thread, and I will be happy to assist you further!
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
10/11/2009 7:23:31 AM •
Mad Dog...
Answered
on Oct 11, 2009
