20 Most Recent Lightning Audio Strike S2.600.2 Car Audio Amplifier Questions & Answers
Also could be that the power wire and earth wires going to amp are to thin amp could be heating up and could be going into protection mode. Will switch on after it cools down what gauge wiring are you using?
Lightning Audio... | Answered on Oct 29, 2018
are you sure there is a power plug needed for the amp? very few amps require power plugs. you merely have to run wires to the power terminal. the power terminal should be labeled - pwr (b+), grnd, and rem.
Lightning Audio... | Answered on Jun 04, 2016
I looked up the specs for the amplifier
  • 4 ohms: 85 watts x 2 channels
  • 2 ohms: 125 watts x 2 channels
So it will take 2 ohm speaker loads, therefore you can parallel 2 speakers together, that is to say connect 2 speakers to the + and - terminals of the left channel and 2 to the right.
4 ohms paralleled with 4 ohms = 2 ohms
So you are OK
Lightning Audio... | Answered on Nov 11, 2017
Take the peak to peak power rating and multiply it by .727
that should be the RMS watts.
You don't have to worry too much about new stuff, but if you are using an older stereo amplifier that is rated for 8 ohm speakers then you should not use 4 ohm or they will pop the finals in the amp.
You could use 2X 4 ohm speakers in series on every channel and it should be ok.
Lightning Audio... | Answered on Jan 31, 2015
the amp probably got to hot and had a thermal shut down witch will have to be fixed by a professional.
Lightning Audio... | Answered on Mar 06, 2010
Attach a picture and give more information on the model and installation.
Car Audio &... | Answered on Aug 02, 2020
Request it from Fisher.
Car Audio &... | Answered on Jul 24, 2020
FULL make and model always. Here are some choices for the JP L5
https://www.google.com/search?q=factory+reset+JP+l5
Car Audio &... | Answered on Jul 20, 2020
Makes no sense. Could be anything. More detail required.
Car Audio &... | Answered on Jul 18, 2020
Watkins woofers are not a normal dual voice coil woofer. They are designed to be used with a special crossover that when one coil starts rolling off due to rising impedance the other takes over to extend the bass frequencies lower. vauygorgxmaaaaaasuvork5cyii=
Car Audio &... | Answered on Jul 09, 2020
E6 error orient 1.5
Car Audio &... | Answered on Jul 06, 2020
Lightning Audio Strike S2.600.2 Car Audio Amplifier Logo
7 questions posted
Top Lightning Audio Car Audio & Video Experts
Marvin
Marvin
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lightning Audio Car Audio & Video
Most Popular Question
amp not switching again after switched
  • Car Audio & Video
