20 Most Recent Samsung CLX-6260FW COL LASER MFP 25PPM GETH WLS DUPLX USB2.0 SCAN COPY FAX 1YR WTY Questions & Answers
chick the sensor
Samsung... | Answered on Jun 25, 2016
Dear
Is there any up-gradation of firmware made?
Pl. upload/inform the display"what ever it may be on printer screen".
Thanks.
Samsung... | Answered on Dec 25, 2014
To reset Samsung printer manually, firstly press the Power button until the LED light turns off. Before proceeding to next step, confirm that your Samsung printer is off. Now, you have to remove the power cable from the back of Samsung printer and then leave your printer unplugged for 10 minutes.
https://www.printerstechnicalsupport.com/how-to-reset-samsung-printer-firmware
Samsung Office... | Answered on Apr 25, 2020
https://www.youtube.com/watch?v=AN973Ko0kX8
Samsung Office... | Answered on Apr 17, 2020
To print a duplex page, follow these steps:
  1. Go to Device and Printers. ...
  2. Right click on the printer, then select Printer Preferences. ...
  3. Below Double-Sided Printing select Long Edge or Short Edge depending on preference. ...
  4. Click Apply and OK to save the changes.
https://support.hp.com/in-en/document/c05589026
Samsung Office... | Answered on Mar 28, 2020
https://www.youtube.com/watch?v=K93j4hdTpZQ
This error is caused by a counter inside your printer not being correctly reset when the new belt is installed. To fix this problem follow the steps below: Press MENU then #1934. Use the arrow keys to navigate to the Tech menu (this is different to the User Mode)
Samsung Office... | Answered on Mar 25, 2020
I searched the internet using https://www.google.com to see if I could locate support information for this printer.
The following link mentions software but didn't show how to troubleshoot the printer for that problem.
https://support.hp.com/us-en/drivers/selfservice/samsung-scx-3201-laser-multifunction-printer-series/19135195
Samsung Office... | Answered on Mar 07, 2020
https://printcopy.info/index.php?mod=erc&brand=Samsung&model=ML4510ND&code=C3-1312
Link to Service Manual above for the ML4510ND model.
Quoting from link above:
Code: C3-1312
  • Display:Imaging Unit Failure: #C3-1312. Install imaging unit again.
  • Description:Toner sensor is defective. The machine can't detect the sensor signal in the imaging unit normally.
  • Remedy:1) Install the genuine samsung imaging unit. 2) If the imaging unit is already installed, check the following. • Reinstall the toner cartridge and imaging unit. • Check if the CRUM connector is normal. • Turn the machine off then on.
Another link to check, page 4-40:
http://www.electis.co.il/files/disfiles/ErrorCodes/A3%202200/K2200_Error_Codes.pdf
Samsung Office... | Answered on Mar 06, 2020
Unplug!
Uninstall all drivers in USB and CD-ROM!
Restart system..
Start fresh installation.
Samsung Office... | Answered on Mar 04, 2020
Samsung CLX-6260FW COL LASER MFP 25PPM GETH WLS DUPLX USB2.0 SCAN COPY FAX 1YR WTY Logo
9 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
scanning connection error
  • Office Equipment & Supplies
