20 Most Recent
Bakers Pride Y-600 Gas Single Oven Questions & Answers
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Why only one side of oven burner will stay lighted fgf326asf
normally you have three types of baking methods.
1. Top only
2. Bottom only
3. Both. -use the setting to this configuration then you will be good to go.
OR
Only one part of your oven is working. THIS can NOT be due to a circuit issue. The other heating wire might be probably damaged. Get it replaced. Will cost you very less about USD5-10.
