20 Most Recent Sharp AR5316 Black Toner / Developer Cartridge Genuine Questions & Answers
change toner cartridge
Sharp AR5316... | Answered on Jan 16, 2015
check if the data notification light is blinking
If no
The machine is in offline mode - Turn ONline
Connector issue - Check printer cable to resolve
Mchine not selected correctly in the application - check printer settings in windows or app
Printer driver issue - Visit the sharp website and download the printer driver and reinstall
If Yes
Check tray setting size
check size of paper
Sharp Office... | Answered on Jun 21, 2020
MFP PWB SRAM memory individual data check sumerror.Detail MFPCause
The check sum value for individual data of thecommunication table and the sender registration doesnot match.MFP PWB SRAM trouble.MFP PWB trouble.Strong external noises.
Check & Remedy
Turn OFF/ON the power to initialize the data related tothe content of check sum error.Since the registered contents are deleted, register thedeleted contents again.Use SIM16 to cancel the error.
Replace the MFP PWB.
Sharp Office... | Answered on May 21, 2020
Replace the PTC unit. Replace the primary transfer unit. Replace the secondary transfer unit. Check disconnection of the high voltage TC PWB connector./Replace. Replace the high voltage TC PWB. Replace the PCU PWB.
Sharp Office... | Answered on May 19, 2020
ou simply reset the error code by pressing : #, interupt, C, interupt, then input 14 then start. Unit should power off and the restart.
https://www.youtube.com/watch?v=4RJZz7CTXuA
Sharp Office... | Answered on May 18, 2020
to get to the number pad you have to double tap the home "button" to the right of the touch screen, then touch the version number in the bottom right corner(even though it doesnt look like a button) to bring up the keypad. then you can go through the procedure above.
H5-01 is the result of 5 jams in a row, so you probably need some maintenance. http://equipmybiz.com/
Sharp Office... | Answered on May 12, 2020
https://www.youtube.com/watch?v=NJj8Vt7YrOw
Sharp Office... | Answered on Apr 09, 2020
Library sec 600 or youtube has info
Sharp Office... | Answered on Mar 16, 2020
MY COPIER SHOWS RED STAR AND HUMAN SIGNS
WHAT COULD BE THE PROBLEM, PLEASE
Sharp Office... | Answered on Mar 12, 2020
a printer,? yah.
NO PC told, this printer is from 2012 era.
that and error? RTM on clearing errors,
first we fix the cause of errors then they self clear. in most cases
push CA, clear all key yet?
or the clear key.
this complex printer is capable of vast errors. covered in the manual here (RTM)
Sharp ar6020 printer read page 111 for CH error,
https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
Sharp Office... | Answered on Feb 27, 2020
This means that the program start information is damaged and could not be loaded. Most likely it will be necessary to replace the operating program of the SD card and then perform a firmware upgrade. Contact an authorized service center.
Sharp Office... | Answered on Feb 21, 2020
Sharp AR5316 Black Toner / Developer Cartridge Genuine Logo
2 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp ar5316 coming white copy
  • Office Equipment & Supplies
