20 Most Recent Sharp Ar 5316 Questions & Answers
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems
Sharp Ar 5316 | Answered on Apr 25, 2018
There is a chance a small piece of paper was left behind from removing a jam. The machine should indicate if the jam is main body or doc feeder. if it is the feeder I will manually run a page through by pushing it and turning the green wheels to feed it. sometimes doing that will catch anything that was stopped up in there and push it out as well. If you are 100% there is no paper in there, then the next step would be to test each sensor in the paper paths and replace whichever one has failed. You will probably want to call a tech for that.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Sharp Ar 5316 | Answered on Feb 21, 2017
If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs and other devices are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Sharp Ar 5316 | Answered on Jul 31, 2016
http://siica.sharpusa.com/product-downloads
try this site and download the op manual;
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp Ar 5316 | Answered on Mar 04, 2016
LASER issue replace the Print Head since you can not just replace the LASER
Sharp Ar 5316 | Answered on Jan 31, 2016
check the scanner feeder rollers and feeder clutch
Sharp Ar 5316 | Answered on Jan 29, 2016
Does the toner cartridge have a electronic chip on it? if so you could refill it all day long it would not change once the chip say the i am done the cartridge is done. Sorry.
Try this site as a start and get a new OEM cartridge
http://olsonbros.com/sharp/parts/list.htm
its the problem with the leser unit
Sharp Ar 5316 | Answered on Nov 19, 2015
25877889-f2p1rwfppgxssdt2ke0xhk4g-5-0.png I would check the connection of the LSU connector before buying a replacement. But the photo I posted explains checks and remedies.
Sharp Ar 5316 | Answered on Oct 25, 2015
install the developer unit , or change developer inside the unit,
and reset using Sim code 42-01
Sharp Ar 5316 | Answered on Feb 24, 2015
Sharp Ar 5316 Logo
20 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp copier ar 5316 showing error
  • Office Equipment & Supplies
