20 Most Recent Denon AVR-1513 Questions & Answers
Short circuited component/s inside the circuit board.
Denon AVR-1513 | Answered on Oct 25, 2015
Power supply section circuit problem. Check all the voltages and filter capacitors at this section. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Denon AVR-1513 | Answered on Jun 02, 2015
Denon AVR-1513 | Answered on Aug 10, 2014
you have to goto setting and set the speaker to tv if you have a newer tv
Denon AVR-1513 | Answered on Mar 28, 2014
How many times this power/standby light blinks? It is fault indication, and are fault codes. If you wish to get some details about these codes, try this link. http://electronicshelponline.blogspot.com
Denon AVR-1513 | Answered on Dec 23, 2013
set the speaker as default, whichever you are testing, it will start working, just right click and select.
Denon AVR-1513 | Answered on Dec 15, 2013
This could be due to the systems overload protection kicking in, which under normal circumstances shouldn't happen, I suggest moving the speakers next to the amplifier and if possible use anew piece of wire to test the speakers start with one and test each individually. I think you possibly have a small short in one of the wires. Or one speaker is damaged. Measure the resistance between each speaker wire pairs. The speaker will probably be either 4 or 8 ohms check that this is the case. Read the speaker labels for clues. Were they the original speakers supplied? by the same manufacturer?
Denon AVR-1513 | Answered on Dec 09, 2013
make sure the wattage of the amplifier has the same amount or more wattage to the subwoofer otherwise it will not be able to produce sound because of power complications
Denon AVR-1513 | Answered on Dec 07, 2013
Check and replace its main system control memory IC.
Denon AVR-1513 | Answered on Aug 23, 2013
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
Denon AVR-1513 | Answered on Mar 22, 2013
Appears to be a software problem. Unfortunately, some blu-ray players contain software that expires, requiring you to repurchase newer, more expensive software from the manufacturer in order to continue to play blu-ray discs. Check your software for the player. No freeware blu-ray software out there.
Denon Televison... | Answered on Nov 13, 2019
Denon AVR-1513 Logo
Popular Tags
24 questions posted
Top Denon Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Televison & Video
Most Popular Question
unit not powering
  • Televison & Video
