20 Most Recent Dyson AM04 HotCool Fan Heater Questions & Answers
Not as warm as when new
Hi there, it's Jack at Dyson. It would be very unusual for there to be any change in warmth in the heated airflow exiting the machine, as the PTC ceramic plates always operate at the same temperature in heater mode. However we're keen to help you check your AM04 is working as well as it should be. When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We can take you through some simple troubleshooting checks, and if a repair or replacement is needed, we can confirm if this is covered under our 2-year warranty. We'll look forward to speaking with you.
9/30/2014 9:03:47 AM • Dyson AM04... • Answered on Sep 30, 2014
Heater does not work
Hi Kent, it's Jack at Dyson. The issue you've described sounds very unusual. If you feel the heater isn't heating the airflow at all, we'd like to provide further assistance to help you resolve this. If the machine needs to be repaired or replaced, we'll be happy to confirm if this is covered under the 2-year warranty. Please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
3/11/2014 4:18:07 PM • Dyson AM04... • Answered on Mar 11, 2014
Hi, my Dyson AM04 fan heater displaying error E4. How to fix it?
2/20/2014 12:46:35 PM • Dyson AM04... • Answered on Feb 20, 2014
0answers
Heater won't work
Hi there, it's Jack at Dyson. AM04 has an intelligent thermostat which you can set to the degree. The machine will then monitor the room temperature and cycle on and off as needed to maintain the temperature you've chosen. If the heater doesn't seem to be running, it may be because the temperature you've selected is below the current room temperature. When the room temperature drops below the temperature you've picked, the heater should come on.For additional troubleshooting to check your machine is working correctly, you might like to visit our Support page:http://www.dyson.co.uk/support/am04/am04-whsilI hope this helps, but if you'd like any further advice, please give us a call. Our Helpline numbers are 0800 298 0298 (UK), or 1-866-693-9766 (US).Best wishes,JackDyson Online Customer Supporthttp://www.dyson.com
12/4/2012 1:49:51 PM • Dyson AM04... • Answered on Dec 04, 2012
H2 error code on Dyson hot/cold fan unit.
what is the question?
7/10/2021 10:18:43 AM • Dyson Dryers • Answered on Jul 10, 2021
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems. If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
8/17/2020 3:11:16 PM • Dyson Dryers • Answered on Aug 17, 2020
DYSON AM08 PEDESTAL FAN HAS OPERATED FLAWLESSLY FOR TWO YEARS ! TODAY I STARTED IT , IT RAN AS USUAL THEN QUIT AFTER A MINUTE. I TRIED AND SEARCHED FOR A CAUSE FOR AN HOUR FOUND NOTHING UNUSUAL. WHAT COULD BE WRONG?
Probably the bearings are dry. remove the fan and housing to get to the shaft and oil it. The circuit breaker is shutting it off because it is drawing excessive current.
9/24/2019 8:58:41 AM • Dyson Dryers • Answered on Sep 24, 2019
My dyson hot and cold fan is displaying code C2 and won't turn on or off
quote from amazon site***Mine also showed H2. I had a suspicion that it was the remote causing it. Changed the remote battery (CR 2032), turned on the heater and let it circulate for 3 minutes, then I went and tested all remote buttons. It worked! No more H2 error code! Amazon Customer ยท September 11, 2018
8/30/2019 6:28:22 AM • Dyson Dryers • Answered on Aug 30, 2019
How to detach Dyson Pedestal AM08 fan?
Call Dyson support, I do not have this answer and a search rendered no results
DYSON USA SUPPORT
Call us at 1-866-693-9766
8/2/2018 10:12:47 PM • Dyson Dryers • Answered on Aug 02, 2018
My dyson heater-fan shows a E8. What should I do?
7/5/2018 1:16:01 PM • Dyson Dryers • Answered on Jul 05, 2018
Dyson AM04 HotCool Fan Heater Logo
Popular Tags
5 questions posted
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
NOEL
NOEL
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
View Most Popular
Dyson Dryers
  • Dyson Dryers
Most Popular Question
not as warm as when new
  • Dryers
