20 Most Recent Dynex Used Original DX40L260A12 Remote Control Questions & Answers
Sounds like back-light inverter section circuit fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dynex Used... | Answered on Sep 23, 2015
Step 1: Turn on your device. Press the GREEN SET button. While holding the GREEN SET button, press the device button you want to program. Release both buttons.
Step 2: Press the GREEN SET button again. The red light should start flashing.
Step 3: Start pressing the power button until your device turns off.
Step 4: Press the device button again.
Step 5: Enjoy!
Dynex Televison... | Answered on Mar 28, 2020
NO , nobody can do that, ever, only testing reveals what is wrong.
a shop does that with tools and documents you do not have and skills.
the TV is 11 years old (2009) the bank lamps can be dead.
for sure most the boards inside can fail, both power ,digital and the back lamps'
why not let a shop do this or upgrade cheaper. like all others do..
Dynex Televison... | Answered on Mar 09, 2020
Remote Control Codes For Dynex TVs
  1. how to program dynex TV with Universal remote control. ...
  2. Turn on the TV.
  3. Press and hold the TV and SEL buttons simultaneously for 3 seconds. ...
  4. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
  5. Verify by pressing the VOLUME + button.
https://www.directutor.com/content/remote-control-codes-dynex-tvs
Dynex Televison... | Answered on Mar 04, 2020
In reality the problem is that you got a generic TV which is Dynex and you really need the genuine remote perform all of the required settings and functions perfectly if you're buying also a generic remote you're going to have difficulty with this you have to try multiple settings before that remote is going to work perfectly
Dynex Televison... | Answered on Feb 15, 2020
Try taking batteries out of remote
Dynex Televison... | Answered on Jan 24, 2020
Here are some universal remote codes of Phillips :
0807, 0022, 0020, 0422, 0122, 0222, 0322, 0002, 0520, 0919, 0521, 0621, 0430, 0247, 0901, 0402, 0408, 0109, 0210, 0310, 0715
Dynex Televison... | Answered on Jan 20, 2020
pretty simple really don't install intake put push rods to hydrolic lifter dish and other end to rocker arm hold in place and tighten nut
Dynex Televison... | Answered on Dec 19, 2019
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dynex Televison... | Answered on Nov 14, 2019
bottom right hand side of screen. directly behind the screen or on the very bottom. the touch sensitive control pads are deceptive. there is no actual "button" per say. try using a flashlight to locate the power symbol along with the menu and volume "button"
Dynex Televison... | Answered on Oct 28, 2019
bottom right side of screen, either on the very bottom or the back of the screen. should be a touch sensitive power button along with menu and volume controls
Assuming it's the right model then it's the button marked number '5' as shown in the diagram as follows...
https://www.manualslib.com/manual/549380/Dynex-Dx-40l261a12.html?page=9#manual
Good luck
Dynex Televison... | Answered on Oct 26, 2019
Open internal fuse or power supply failure
Dynex Televison... | Answered on Sep 19, 2019
i dunno but mine is doing it and i have only uad it for 1 year
Dynex Televison... | Answered on Jul 19, 2019
None listed. Use code search to find it. If a search through all codes stored in the URC fails, try a different one.
Dynex Televison... | Answered on Jul 12, 2019
What needs to be adjusted is picture size, not aspect ratio. Your Dynex may or may not have such a provision.
Dynex Televison... | Answered on Jun 17, 2019
Dynex Used Original DX40L260A12 Remote Control Logo
1 questions posted
Top Dynex Televison & Video Experts
Vitally Alcher
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Televison & Video
Most Popular Question
acting up sound but no picture
  • Televison & Video
