20 Most Recent Insignia New Original NSRC06A11 Remote Control Questions & Answers
My insignia tv in the bedroom has no signal. It was working fine till I undid the cable in the living room. Moved the tv in the living room ...reconnected it. And now no signal in the bedroom.
Insignia... | Answered on Sep 19, 2020
Make sure that the audio cables are properly connected for the source (component, composite video or VGA/DVI (computer or other device)). Disconnect any cable in the headphone port.
Was the TV ever used with an audio receiver? If so, the TV speakers may have been turned off. Go to the Home Menu. Go to Settings > Display and Audio > Audio Output > TV Speakers and set this to On. (For Quick settings, press and hold Home. Then go to Sound > TV Speakers and set to On.) If you have a universal remote, the remote could be set to give all audio commands to a receiver. Try the remote so the Audio commands go to the TV. (This will depend on the remote. Please add a comment with the remote brand, model and type (often inside the battery compartment) for the full programming information.)
If you are using external speakers with a receiver, you may need to change the audio settings to PCM for a digital audio output. (This is in the same Audio Output section of the standard menu.)
I hope this helps.
(I've locked several remotes to the audio system which causes this type of problem when the home theater system needs a wiring repair.)
Do a factory reset to this set, and then check. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://remotesearch.blogspot.com/
https://electrohelponline.blogspot.com/
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
Insignia... | Answered on Jul 23, 2020
You are better off not trying to locate a schematic. Manufacturers dont release that information any longer. There is no market for it when parts can just be swapped and not subjected to troubleshooting and component replacement.
Insignia... | Answered on Jun 19, 2020
Check the control voltage that comes to the backlight inverter board. If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Insignia... | Answered on Jun 02, 2020
What model of TV?
Press the Input or Source button on the TV (side top or bottom of TV) until it reads TV or ANT.
Cheers,
Insignia... | Answered on May 28, 2020
It will be best for you to contact any experienced service personal in the case. This is not a user repairable fault, as you thinks.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Insignia... | Answered on May 18, 2020
https://www.youtube.com/watch?v=EtJ8UrX0vAM
Insignia... | Answered on Mar 24, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Insignia... | Answered on Mar 08, 2020
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Insignia... | Answered on Feb 12, 2020
Insignia New Original NSRC06A11 Remote Control Logo
0 questions posted
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
insignia 55 inch tv come after bout 5 or
  • Televison & Video
