20 Most Recent
Sanyo RMT-U100 RMT-U100 Tv/Cable/Vcr Remote Control P/N: Rmt-U10 Questions & Answers
How to setup sanyo dp50747 tv with no remote
If you do not have the remote control for your Sanyo DP50747 TV, you can try using the buttons on the TV itself to set it up. Here are the steps to follow:
- Locate the power button on the TV. This is usually a round button with the power symbol (a circle with a line through it) or a triangle with a line through it. Press the power button to turn on the TV.
- Locate the input button on the TV. This is usually a square button with the input symbol (a rectangle with an arrow pointing into it) or a button labeled "Input" or "Source". Press the input button to cycle through the available input options (e.g. HDMI, AV, etc.).
- Once you have selected the appropriate input, you should see the setup screen for your TV. Use the arrow buttons on the TV to navigate through the menus and select the options you want to change (e.g. language, time zone, etc.).
- To save your changes, look for a button labeled "Menu" or "Options" on the TV and press it. This will bring up the main menu, where you can select the "Save" or "OK" option to save your changes.
Note: If you are unable to navigate through the menus using the buttons on the TV, you may need to use a universal remote control or purchase a replacement remote for your TV.
I have a white screen on my sanyo tv
Try unplugging your TV for about 10 minutes and also hold the power button on the TV for about one minute and then plug your TV back in again and turn it on to see if the white screen is still showing up again. It could be the capacitors inside of the TV have gone bad or the powerboard is not working.Check the cables and the connections to your TV to make sure they are fully connected. Or the TV connections are bad and should be replaced.
I have a sanyo remote and I'm trying to us a Magnavox tv/DVD tv
If it is a Sanyo UNIVERSAL remote, here are the codes. It it came with a Sanyo television, it is single frequency and can't be changed.
CODE LIST - Magnavox
https://www.magnavox.com > controller=attachment
PDF
Brand of TV. (Device Selection Buttons: TV Button). Codes: Admiral. 0129,0130. Advent. 0036. Akai. 0102,0117,0034,0090. AOC. 0058,0063,0093,0096,0024.
