20 Most Recent Concord Camera Eye-Q 4360z Digital Camera Questions & Answers
Say more about the poor outside images - whats wrong with them?
Concord Camera... | Answered on Apr 04, 2008
I suspect it has died on you. and there will not be a repair option Dee
Concord Camera... | Answered on Aug 21, 2007
Well they are correct for so many small electronics these days- not always a bad product- simply the way these things are made on huge machines - there is no human intervention- ie. soldering minuscule parts on tiny circuit boards-possible. Buyit -breakit- binit seems to be the order of the days- Kettles/Toasters/Irons /All the same All made in China all not worth tuppence
Hello This is a pretty usual type of problem. The lens assembly is composed of some lens and some servomotors that will move them around or focus them properly in order to get a sharp picture. This is a delicate part of any camera. Sometimes one of the small parts in the lens assembly get out from their positions and damages or jams other components there. Therefore when you start the camera it produces weird noises as it tries to extend the lens. A camera doesn't know where the lens are at the moment you start it. It will power up the motors for a small amount of time, as it knows that if the motor works for about 1-2 sec the lens should move and extend. If this doesn't happen the camera gets confused and gives you errors or makes strage noises as it powers on the motor but it can't move the lens because they got jamed or are fully extended. Only a service center can fix this because lens mechanisms are very fragile and require specialised hardware to be realigned or repaired. In your case it would be adviceable to ask them an estimate of the repair, for you to know if it's worth it. It can be a simple job like putting back the piece that got out of place, but also it can be a situation in wich the whole lens assembly must be changed because of extensive damage recieved when the motor forced the lens to extend. It is also a good thing to do, NOT to power on the camera anymore as it can damage itself furthermore. Sorry as I can't give you more detailed tips, this isn't the do-it-yourself type of repair, even the service centers are having problems with this repairs. Good luck however, maybe it's a simple thing.
Concord Camera... | Answered on Mar 17, 2007
Is this something to do with the Famous Flames ? It certainly has no relevance to cameras.
Concord Cameras | Answered on Dec 23, 2019
You didn't specify the model of your Concord camera, but most of them take SD cards. SD cards are getting a little hard to find, but you should still be able to find them at most department, electronics, and office-supply stores. Check the manual to see whether your camera also can take SDHC cards. SD cards are limited to 2GB or smaller, while SDHC cards go from 4GB to 32GB.
Concord Cameras | Answered on Mar 03, 2014
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Concord Cameras | Answered on Apr 30, 2011
In order to test the memory card you may please shoot a few pictures and then try to transfer them on to the computer.
Also, you may take the card out and connect it with a card reader.
Try to create a file on that and save it.
These cards are storage devices like the USB Pen drives we use.
If you are able to get data on and off it, it is working just fine.
You may format the card and then use it on your camera.
If you require any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Concord Cameras | Answered on Jan 23, 2011
Unfortunately, if the manual states a card size, that is usually the largest card the camera will accomodate. I'm not sure if it would take a 1 gig card, you never know till you try.
Wish I had better news, but I have an old Olympus and it won't take any card larger than the 500 mb card.
Concord Cameras | Answered on Sep 15, 2010
http://www.birseyindir.net/pdriver/digital/eyeq3x_dr.zip
Hope this helps!
Tom
Concord Cameras | Answered on Jul 29, 2009
You need to delete stuff on the memory card or put a empty memory card in there
Concord Cameras | Answered on Sep 06, 2008
ask GOOGLE
Cameras | Answered Yesterday
This query has no relevance to photography, unless it is making your hands shake. If it is, use a higher shutter speed.
Cameras | Answered on Jan 17, 2020
Concord Camera Eye-Q 4360z Digital Camera Logo
4 questions posted
Top Concord Cameras Experts
klasspappa
Level 1 Expert
ray gallant
Tony Parsons
Tony Parsons
Are you a Concord Camera Expert? Answer questions, earn points and help others
View Most Popular
Concord Cameras
  • Concord Cameras
Most Popular Question
picture outside in day light overexposed
  • Cameras
