20 Most Recent
Philips Aquatouch At890 Wet And Dry Rechargeable Electric Shaver With Pop Up Trimmer Questions & Answers
Philips at896 stopped working
If it's not in warranty, dissassemble the shaver and check for water inside.
Either dry it out in a warm cupboard or displace the water with WD40
1/7/2014 1:17:16 PM •
Philips...
Answered
on Jan 07, 2014
Philips Shaver Faulty
Replacement under warranty involves promising to remove the battery from the old shaver and disposing of the battery and the carcass in an environmentally safe way.
The shaver can be split apart after removing three torx screws and then prising the plastic parts apart against their clips. Be VERY careful when releasing the plastic clips inside because they are brittle and fragile.
On opening the cover containing the battery, motor and control circuitry the ingress of water was clear. The shaver is supposed to be wet and dry, has only been used dry but the exterior has been washed.
The water was displaced using WD40. The shaver operated normally straight away. If your shaver's motor starts with the button but stops again half a second later, the problem might be caused by water ingress.
12/23/2013 9:02:22 PM •
Philips...
Answered
on Dec 23, 2013
