20 Most Recent Dacor ECS230 Epicure Electric Double Oven Questions & Answers
Daco oven - U60 cooling fan error
Still active problem?
7/26/2017 10:01:06 PM • Dacor ECS230... • Answered on Jul 26, 2017
0answers
CAN'T GET MY DACOR OVEN LIGHTS TO WORK AFTER REPLACING BULBS
take the bulb back out and check to see if the prong that hits the bottom of the light bulb is making contact. If that don't work then its most likely going to be a short or a wire problem of some sort...Do all the basics first the work your way down...It should be to hard if your willing to go further if necessary...If not then its time to call the tech...Hope this helps you out..
12/17/2014 2:22:28 AM • Dacor ECS230... • Answered on Dec 17, 2014
2answers
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
11/1/2014 5:58:40 PM • Dacor ECS230... • Answered on Nov 01, 2014
Oven is dead
Is it the entire oven or just the heating element?
11/6/2013 7:46:13 AM • Dacor ECS230... • Answered on Nov 06, 2013
I had both ovens on for a party, someone tried to change time on the timer, pressed all kinds of buttons, now both ovens say OFF and I cannot get anything to work, any suggestions how to get out of th
Turn off amin power wait for a few min's then turn power back on it should come up normal , let's hope so !
12/6/2011 4:46:27 PM • Dacor ECS230... • Answered on Dec 06, 2011
Upper over will not heat
Try to either reset a resetable thermostat (inside by the door latch) or replace a relay board.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
1/26/2011 6:45:37 AM • Dacor ECS230... • Answered on Jan 26, 2011
Top convection oven bottom element doesnt work
Follow wires & make sure they have not burned into. Tug on them at terminals. p.s. make sure power is off before doing this.
12/6/2010 6:50:48 PM • Dacor ECS230... • Answered on Dec 06, 2010
Oven is locked cancel/secure bottom is not working
Try pressing in on the door while trying to release it. The friction of the latch may be keeping the latch from opening.
11/26/2009 7:08:14 PM • Dacor ECS230... • Answered on Nov 26, 2009
2answers
My oven won't heat after
hello this often happens after cleaning. What has occurred is the heating element was on its last legs and that self cleaning reswulting in extreme heat for a long time did it in.
you will have to have a technician come in and replace the heating element.
10/8/2009 2:38:08 PM • Dacor ECS230... • Answered on Oct 08, 2009
My upper oven/ convection function on my dacor
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
9/28/2009 1:32:48 AM • Dacor ECS230... • Answered on Sep 28, 2009
0answers
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
11/27/2008 6:27:27 PM • Dacor ECS230... • Answered on Nov 27, 2008
4answers
My selfcleaning oven throws a breaker when I turn it on
unplug the oven from the main power cord for sometime.then ON and set all the things again properly.
11/23/2008 12:32:47 AM • Dacor ECS230... • Answered on Nov 23, 2008
4answers
We clean are double wall
Hi williamk77,
Your post "reset the clock" may refer to three (3) clocks in your Dacor ECS230. The first is the "Setting the Time of Day" which could be performed by pressing on the "CLOCK" touchpad. The time of day will falsh. "AM" or "PM" will be displayed and "TIME" will flash in the display. Thereafter, press the touchpad "+" or "-" until the correct time of the day is displayed and release touchpad.
The second is the "Using the Minute Timer" which is better explained at the user's manual page 6. Below is a snapshot of that part of that page.09d8cbe.jpg
and the third is "Timed/Delayed Timed Cooking" likewise better explained at the user's manual (p.9). Should the manual be not readily available, it may be downloaded from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
5/3/2008 2:39:01 PM • Dacor ECS230... • Answered on May 03, 2008
Dacor ECS230 Epicure Electric Double Oven Logo
35 questions posted
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
View Most Popular
Dacor Ovens
  • Dacor Ovens
Most Popular Question
bottom oven dacor double oven
  • Ovens
