20 Most Recent Dacor ECD227 Epicure Electric Double Oven Questions & Answers
Usually when an oven is slow to heat, it is because of a bad element. You can look at the upper (broil) and lower(bake) and see if they appear to have any major burn marks on them, It may just look like something spilled on it untill you look closer or try to clean it off. if you do not find any obvious problems, turn the oven on and wait a fem minutes, then see if the bake element is glowing. Also look at the broil element, they should both be glowing at least a little orange. Compare how it works to the other oven that works properly. If only one of your elements is glowing, either you have a bad element (which is usually apparent on visual inspection) or a bad relay board that controls the element. The element is easy to change, onlt a couple screws and 2 wires (turn off the breaker first!!), the relay board is pricey, and a pain in the tookas. if you decide to guess, try the element first. Hope this is at least a little helpful.
Dacor ECD227... | Answered on Mar 24, 2020
usually located inside the oven near the top left but varies in other models, at bottom, at top, it looks like a tiny thin pc of tube or metal or glass and held by a couple screws
Dacor ECD227... | Answered on Mar 02, 2015
Possibly needing to screw them in a little tighter, please disconnect the mains power before doing so
Dacor ECD227... | Answered on Jul 06, 2014
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Here is a direct link to the ONLINE USER'S MANUAL for the DACOR 227 model ovens:
http://www.ajmadison.com/ajmadison/itemdocs/59D19961-6587-4C15-8011-3AC1F6877ABB.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this utility pre-installed.
You can always download this for free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If you were satisfied with the service provided, could you please take a moment to leave a 5 STAR rating. Your feedback is very important and I truly appreciate your consideration.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
Here also are some additional documents and diagrams for that model:
http://www.apdepot.com/images/PartsLookup/DACOR/PM_CPTS_CPTD.PDF
http://ww1.dacorservice.com/PartsCatalog/docs/Wall%20Ovens/WD/CPT_WD.pdf
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dacor ECD227... | Answered on Dec 04, 2011
Hi.Lert me just clarify if the panel board you are referring to is the breaker or the circuit breaker. Now you can actually check the terminal end of your unit by removing the back cover.unscrew it and usually it will b e poasitioned vrtically and horizontally.It is located at the upper right back corner of your unit.You can actually check if there was an open circuit or short circuit happened that possibly why your oven is not working well.CHECK FIRST THE CONTINUITY OF THE CIRCUIT unit using a multitester.Unplug first the unit.set the tester to ohms lowest value times 10 multiplier value.now check live wire 1 by 1 .connect 1 end of the tester to a live wire and the other line to the neutral or. ground wire usually a white wire.now check if the testers opointer move or not.If it does not there is an open circuit but if it reached infinite or maximum value then circuit is short-circuited.which means two lines nolonger separated by an insulator probably it was burnt.Now if this is the scenario,you may as well consult it to a technician because they will test each ic on the circuit on the control panel of the unit (not the breaker).hope this idea helps you to figure out what'S happening on your unit.Thank you for bchoosing FIXYA.
Dacor ECD227... | Answered on Jul 18, 2011
F0 means shorted keypad or stuck key on keypad.
Solution: The membrane aka keypad has to be replaced.
There's a slight chance that the ERC aka oven controller is acting up also.
So safest bet replace both, ERC and membrane.
Dacor ECD227... | Answered on Jan 12, 2011
The relay will not hold a closed circuit for the heating / timer module. You will need to have it serviced
Dacor ECD227... | Answered on Jan 24, 2010
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Dacor Ovens | Answered on Nov 15, 2020
FixYourBoard.com will test and remanufacture the relay oven control board in this model. Each rebuild comes with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
Dacor Ovens | Answered on Mar 24, 2020
Dacor Ovens | Answered on Mar 20, 2020
were the both the same voltage and don't touch the bulb with your fingers us clean rubber gloves
Dacor Ovens | Answered on Feb 02, 2019
Dacor ECD227 Epicure Electric Double Oven Logo
18 questions posted
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
View Most Popular
Dacor Ovens
  • Dacor Ovens
Most Popular Question
dacor double oven gives error
  • Ovens
