20 Most Recent Huawei M660, Ascend G300, U8815 Battery - 1800mAh Questions & Answers
0answers
What is the difference between H901MPLB and H901MPLA?
Here is the comparison
Main features of MPLA and MPLB control boards
Huawei https://forum.huawei.com > enterprise > thread Aug 6, 2023 - There are three hardware versions of MPLA - H901MPLA, H902MPLA and H903MPLA, and two hardware versions of MPLB: H901MPLB and H902MPLB. Detailed information ... Mapping between Control Boards of MA5800 Series Mar 20, 2020 MA5800 board substituition Jul 25, 2022 MPLA MPLB difference May 28, 2021 More results from forum.huawei.com
11/23/2023 8:56:19 PM • Huawei Computers... • Answered on Nov 23, 2023
3answers
Does Huawei ME60 router support the PPPoE function?
Yes, ME60 series router support PPPoE function by default.
11/3/2023 5:08:55 PM • Huawei Computers... • Answered on Nov 03, 2023
Hi i want to change my password on my Huawei router. how do i reset it . Thanks
To reset the password on your Huawei router, you can follow these general steps:
  1. Access the Router Settings:
    • Connect your computer or mobile device to the Huawei router via Wi-Fi or an Ethernet cable.
    • Open a web browser and enter the default IP address of the router in the address bar. The default IP address for Huawei routers is often "192.168.1.1" or "192.168.0.1". If these addresses don't work, you can check the router's documentation or look for the default IP address on the router itself.
    • Press Enter to access the router's login page.
  2. Log in to the Router's Configuration Page:
    • On the login page, enter the username and password. The default login credentials are usually provided on the router or in the documentation. Common default usernames and passwords for Huawei routers are "admin" for both the username and password fields.
    • Click on the Login or Sign In button to proceed.
  3. Navigate to the Password Settings:
    • Once you are logged in, find the settings section related to Wi-Fi, Wireless, or Security.
    • Look for an option named "Password," "WPA Key," or "Pre-Shared Key" to change the Wi-Fi password.
    • If you want to change the router's administration password (used to access the router's settings page), look for an option like "System," "Administration," or "Management" settings.
  4. Change the Password:
    • Enter your desired new password in the appropriate field.
    • Make sure to choose a strong and secure password that includes a combination of letters, numbers, and special characters.
    • Some routers may require you to re-enter the new password to confirm it.
  5. Save the Changes:
    • After entering the new password, look for a "Save," "Apply," or "Submit" button to save the changes.
    • Click on the appropriate button to save the new password.
  6. Test the New Password:
    • Disconnect any devices currently connected to the Wi-Fi network.
    • Reconnect the devices to the Wi-Fi network using the new password to ensure it is working correctly.
6/28/2023 2:51:43 AM • Huawei Computers... • Answered on Jun 28, 2023
How many GPON or 10G GPON ports does CGHF have?
CGHF board is an 16-port XG-PON and GPON Combo OLT interface board for Huawei SmartAX MA5800 series OLT. It works together with the optical network unit (ONU) to provide XG-PON and GPON access services. 16 XG-PON&GPON ports (SFP+) Maximum split ratio 1: 256 Port rate: GPON upstream: 1.244 Gbit/s GPON downstream: 2.488 Gbit/s XG-PON upstream: 2.488 Gbit/s XG-PON downstream: 9.953 Gbit/s Rate mode: Asymmetric rate Forwarding capability: 200 Gbit/s
2/26/2023 12:23:35 PM • Huawei Computers... • Answered on Feb 26, 2023
How to do Speed Limits over Huawei Switch?
1/9/2023 11:17:20 AM • Huawei Computers... • Answered on Jan 09, 2023
What's the difference between Huawei X2CS and X2CK card?
There is basically no functional difference between X2CS and X2CK cards, and they can be used as replacement models
12/28/2022 8:59:20 AM • Huawei Computers... • Answered on Dec 28, 2022
Huawei B315s-22 router will not accept "admin" password after factory rest
If your Huawei B315s-22 router is not accepting the "admin" password after a factory reset, there may be a few possible causes for the issue. Here are some steps you can try to fix the problem:
  1. Check the router label: Make sure that the username and password listed on the router label are correct. It is possible that the label may have been damaged or misprinted, in which case you may need to contact Huawei or the retailer where you purchased the router for assistance.
  2. Check for firmware updates: Make sure that the router has the latest firmware installed. You can check for updates on the Huawei website or through the router's web-based interface.
  3. Check the caps lock key: Make sure that the caps lock key is not enabled on your keyboard, as the password is case-sensitive.
  4. Reset the router again: If the above steps do not help, you may need to try resetting the router again. To reset the router, locate the reset button on the back of the router and press and hold it for 10-15 seconds until the power light starts flashing. Then release the button and wait for the router to restart.
If none of these steps help, you may need to contact Huawei or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the router for any troubleshooting tips or recommendations.
12/21/2022 10:15:27 AM • Huawei Computers... • Answered on Dec 21, 2022
Can I use compatible SFP/SFP+ module on Huawei S5720-52X-PWR-SI-AC switch?
Yes,S5720-52X-PWR-SI-AC supports compatible SFP, but the switch may generate alarm, however, it will not affect normal use.
9/18/2022 4:32:45 PM • Huawei Computers... • Answered on Sep 18, 2022
Huawei y5p not responding
Here are some ways to fix such an issue: Reboot your phone This is the most common method to fix an unresponsive touch screen issue of your Huawei Y5p. Yes, rebooting your phone clears all processes running in the background and makes its memory free. This process also makes the apps run smoothly. So, try rebooting your phone. This should fix your problem. Not solved yet? No worries. You can try few more methods which we have mentioned below: Boot into safe mode Safe mode lets your Huawei Y5p boot to its original condition when your mobile was first switched on. Safe mode disables all third-party applications on your Android phone for a temporary basis. You can get back to the original condition of your phone by just rebooting your device. Want to boot your Huawei Y5p into safe mode? Here's what you have to do: Press and hold the Power Button > Menu will pop up > Press and hold the Power off symbol for 3 to 4 seconds > You'll see, "Reboot to safe mode" notification > Press Ok. That's it. Now you are in safe mode. Check whether your touch screen works properly in safe mode or not. If it's working well then you have a problem with some select third-party apps which you have recently installed on your phone. We suggest you uninstall those applications & reinstall them. Factory Reset [ How to fix Huawei Y5p unresponsive touch screen isssue ] You might have used this method previously for fixing some other issues related to your phone. With this method, all the data in your Huawei Y5p will be erased and your phone will be like a newly purchased device (PS: Just don't expect the same performance). By Factory resetting your phone, all the data stored by third-party apps, and sometimes the setting of the device which was changed by such apps will be restored to default. Before applying this method, remember that all data in your device will be permanently cleared. So back up your important files. To factory reset your Huawei Y5p: Open Settings > System > Advanced > Reset Options > Erase all data (factory reset) > Click on "Reset Phone." In addition to this, you may be asked to enter your password at the end of this process & that's it. After performing a factory reset your phone's touch screen should have to work properly. Regards, Rachel Gomez
9/12/2022 5:43:01 AM • Huawei Computers... • Answered on Sep 12, 2022
3answers
What is the difference between Huawei 2700 switch and 2300 switch?
Huawei S2700 target the enterprise market, S2300 target at telecom market, but most function are the same, the manufacturer did this mostly for marketing reasons as the telecom market most are big customers with better discount.
9/11/2022 10:17:00 AM • Huawei Computers... • Answered on Sep 11, 2022
What is the CWMP? What's the function of it?
CWMP providing communication between a customer premises equipment and auto-configuration servers. It includes both a safe auto - configuration and the control of other CPE management functions within an integrated framework. 1)Autoconfiguration in which we creat files for different categories of CPE on the ACS. 2) Software image management when the ACS finds a software version update the ACS notifies the CPE to download the software image fgile from a specific location. 3) Data Backup in which the ACS can require the CPE to upload a configuration or log file to a specific location.
8/23/2022 9:27:42 PM • Huawei Computers... • Answered on Aug 23, 2022
Can i use my huawei router without a switch box since im trying to connect using wifi ?
Hi, Please review your manuals table of contents to see if this is possible . You can also call Huawei at 1-877-448-2934. Thank you.
7/27/2022 11:40:39 PM • Huawei Computers... • Answered on Jul 27, 2022
How do I find the WEP key of a Huawei EG8145V5 router?
It should be on a sticker on the router itself or in the installation instructions. https://www.google.com/search?q=Huawei+EG8145V5+router%2C+find+the+WEP+key ..
7/3/2022 1:21:13 AM • Huawei Computers... • Answered on Jul 03, 2022
What type of cabinet does the Huawei MA5800-X17 use?
The supported Huawei MA5800X17 cabinets are: N63E-22 and N66E-18
5/25/2022 9:24:30 AM • Huawei Computers... • Answered on May 25, 2022
I bought Huawei EG8120L ONT, can I use it with other brand OLT?
It's okay to use EG8120L with other OLT but not suggested, as the understanding between different vendors on TR069/OMCI may be different.
4/29/2022 8:15:00 AM • Huawei Computers... • Answered on Apr 29, 2022
Does Huawei MA5800 X17 support the Multicast?
ask them we are no them, and is a complex comm system not a computer. simple. https://support.huawei.com/supportindex/index ask them in SUPPORT.
12/24/2021 7:28:31 PM • Huawei Computers... • Answered on Dec 24, 2021
Can I use compatible SFP/SFP+ module on Huawei S6720 switch?
Huawei ask them on their web site? and get better answers . https://support.huawei.com/supportindex/index
12/24/2021 7:28:23 PM • Huawei Computers... • Answered on Dec 24, 2021
Huawei M660, Ascend G300, U8815 Battery - 1800mAh Logo
5 questions posted
Top Huawei Computers & Internet Experts
Ngoro
john h
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Huawei Computers & Internet
Most Popular Question
forget passwords s5700 switches huawei
  • Computers & Internet
