20 Most Recent
Dacor EHD3618SS Kitchen Hood Questions & Answers
To whom it may concern: I paid $30.00 through my
Well... Californi543,
That certainly takes all the fun out of
PROVIDING totally
FREE advice...
(152,000 times for nary a cent).
Do us all a FAVOR... Immediately call the ## on the
back of your
VISA and report the
Then... do the responsible thing and complete
a
POLICE REPORT.
Even is a underpaid... vigorously abused POLICE FORCE
like OAKLAND... our (unappreciated) heroes in Blue still appreciate a CITIZENS effort to help enforce the law...
A caller ID or a little VISA cooperation maybe all it
takes to end a serious crime spree...
But even VISA can't be tossing CREDIT CARD
information around without a POLICE REPORT...
So yes... THE BALANCE of RIGHTEOUSNESS stands on your action...
Please do follow through.
Carnac the Magnificent
How do you get the light bulb out of the hood?
there is a tool (suction cup) that dacor provides with unit or you can order the "kit" online for $30. i used some gloves with latex coating on palms to get "decent grip" to spin it out. that stainless stell rim actually pops out on my ventilation hood....it is similar to recessed lighting baffles...spring loaded....it may give you a bit more room to manuever your fingers.
Took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
What if you don't have the suction cup/light
i used two thin strips of metal shaped on the ends like the bulb i was putting in ,i tied these together with a rubber band and then applied finger pressure up by the bulb ,it came out ,but is a terrible design
Fan toggle switches
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Hot change out the hood
Good Luck!!
Thanks!!
How do you change the
Using your finger nail or a small flat-head screwdriver, gently depress lens retainer tabs. and take the balbs out...
How do you take out light ballbs from dacor hod fan
To replace the light bulb:
1. Remove the right filter and turn off the main power
switch.
2. Gently push the suction cup on the light replacement
tool A (provided with you range hood)
onto the lens of the light bulb B .
3. Turn the tool counter-clockwise until the bulb
comes loose.
4. Remove the tool from the bulb and put it on the
lens of the replacement bulb.
5. Screw the new bulb into the light fixture clockwise
until it is tight. Turn on power at the fuse or junction
box. Turn on the main power switch and touch
the light key to make sure it is working.
6. Replace the filter.
You can download the manual here.
Good Luck And please Rate FixYa!
Dacor cooktop - one of the burners' igniter does not spark. Need to investigate what's wrong but do not know how to gain access
To access the spark module and switches underneath the spill tray of your Dacor cooktop, you may need to remove the burner and base assemblies. Here are the steps you can follow:
- Turn off the power to the cooktop by unplugging it or turning off the circuit breaker.
- Remove the grates, burner caps, and burner bases from the cooktop. Depending on the model of your Dacor cooktop, you may need to use a screwdriver or wrench to remove the screws or bolts that hold the burner bases in place.
- Carefully lift the spill tray out of the cooktop. If it seems to be stuck, check for any screws or bolts that might be holding it in place and remove them.
- Once the spill tray is removed, you should be able to access the switches and spark module underneath. Check for any loose connections or damaged components that may be causing the igniter to malfunction.
- If necessary, replace the faulty component or components. You can find replacement parts for your Dacor cooktop online or at a local appliance store.
- Reassemble the cooktop in reverse order, making sure all the components are properly aligned and securely fastened.
- Turn on the power and test the burner to ensure that the igniter is working properly.
Note: If you are not comfortable working with gas appliances or if you are unsure about any of the steps, it is recommended that you seek the assistance of a qualified technician.
