20 Most Recent Daewoo Vcr Player Video Player Recorder Vcr Vhs 4 Head Questions & Answers
http://www.wikihow.com/Clean-a-DVD
Daewoo Vcr... • Answered on Sep 25, 2015
I can't find information online about your monitor, so I'll give you a generic answer for all monitors. Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters) C13 image: 173-0602-e.jpg C7 image: ac15wna-r.jpg C5 image: 173-21103-e.jpg These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors. There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it. It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
Daewoo Computers... • Answered on May 08, 2014
Yes, what`s the mainboards name ???Try to seach at the pc manufactures homepage.Good luck
Computers &... • Answered on Jan 13, 2013
download from manufacturers website
Daewoo Computers... • Answered on Oct 16, 2010
Hi
I've fixed this problem on a number of monitors recently, its a very simple and easy to fix problem. But you have to take the monitor apart and replace a few electrolyte capacitors from the power supply board.
A local electronics repairer can repair this for you. or you can do this yourself. Any TV, Video, etc repairer can do this simple repair.
Here is a very good picture of bad and good capacitors I found from another fixya Expert.
Your problem is probably 1 or 2 bad capacitors, you will notice a faulty capacitor from its top, if its not flat / level, then it needs to be replaced.
Replace the capacitor with a same voltage cap, the UF rating has to be the same or it can be higher, but not lower. If for example you have one faulty capacitor in the display its 16V (16 volts) and 1000 UF, you can replace it with a 16V 1600UF capacitor for example. Would recommend to replace with the same value.
Let me know if you need further instructions or if you need help in taking the display apart or if you need anything else. I'm sure I can assist.
Daewoo Computers... • Answered on Sep 21, 2010
is there a "wake up" key on your keyboard? if yes,try using that?
Daewoo Computers... • Answered on Feb 04, 2010
That's because Monitors don't have fuel pumps.
Daewoo Computers... • Answered on Oct 13, 2009
My guess is it is a programming glitch of the ALT key correctiable by BIOS modification rather than physically addressing. Such fixes are tried at your own peril and without guarantee of working (or even the computer working) after such. https://aatayyab.wordpress.com/2019/12/19/when-a-key-on-a-computer-keyboard-gets-stuck-keyboard-codes-and-their-hex-scan-code-values/ https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/very-odd-0210-stuck-key-error/3885128d-6bb7-4442-a669-73b14bf58bff That said, I would be awfully tempted to try an alternative keyboard (a rather dodgy idea if it is a laptop).
Computers &... • Answered 54 minutes ago
hi - we got disconnected (accidentally ended the chat session?)
for the light pattern that you have here are the related issues:
paper jams , obstructions , cover error
Canon's recommendation:
Resetting the Printer By resetting the printer'spower, the print bufferis cleared and certain sensors are reset. Ifthere is invalid data inthe buffer, or sensors are stuck in aparticular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplugthe printer's power cord for approximately 10minutes, and then plug itback in. If troubleshooting a communicationissue, reconnect the datacable (not applicable to WiFi, Bluetooth orInfrared).
  4. Turn the printer back on.
Note:Ifresetting the printer does not work, please attempt any othersolutionsthat appeared in your search results.If this is a hardwareerror on theprinter, the printer may need to be repaired.
Issue: Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Solution: The iP1700 may require repair
Unfortunately,the issue you describe seems to indicate that yourproduct may requirerepair service. If you feel your product mightrequire service, aTechnical Support Representative will be happy toanswer any questionsyou may have and explain the service optionsavailable to you. You cancontact us through the email link or phonenumbers listed below.
  • Obtain Support by Email
  • Fortoll-free technical support, please call 1 (800)828-4040 duringregular business hours (currently Monday-Friday 10:00a.m. - 10:00 p.m.EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
The InstantExchange Warranty Program is available:
(1) only for certain printer, facsimile, multifunction, and scanner models;
(2) during the express limited warranty period for such products; and
(3) only in the continental United States, Alaska and Hawaii.
Sowe may better assist you, please make sure that you can accessyourCanon product and have the following information available whenyoucall:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already done to try to solve the problem.
For information regarding the Canon U.S.A., Inc. Limited Warranty, please click here.
Welook forward to helping you rectify the issue you are experiencingandare always available to provide any assistance you may need.
Computers &... • Answered 11 hours ago
The problem you are facing may be due to the corruption of system files. You could use the following troubleshooting methods and check whether they help in solving the issue. Solution 1: Reset the Windows explorer Step 1: Press Ctrl+Alt+Delete at the same time and choose to launch Task Manager. Step 2: Find Windows Explorer/Explorer.exe in the window and right-click on it. Choose End Task. Step 3: After that, navigate to File > Run New Task, type explorer.exe, and click OK. Step 4: Now, restart windows explorer and check whether the error persists. If the issue still persists try the below solution. Solution 2: Clean boot your computer Step 1: Press Win + Q and type in System Configuration. Step 2: Navigate to Gerneral, uncheck Load startup items option under Selective startup. Step 3: Now, turn to Services tab, select Hide all Microsoft services, and then click on Disable all. Step 4: Restart your PC to check if the problem persists or not. If the problem still persists after you have tried out the two solutions, you could refer to this article to learn other fleshed-out ones: 10 Solutions to Fix Windows Explorer Has Stopped Working Error
Computers &... • Answered Yesterday
To fix issues with your Echo device not responding:
  1. Make sure you're using the power adapter that was included with your device.
  2. Make sure you have an active internet connection.
  3. Check that your device isn't muted. ...
  4. For devices without a screen: press the Action button to see if your Echo device responds.
More items...
Amazon.com Help: Alexa Doesn't Understand or Respond to ...
https://thegeekpage.com/fix-this-application-requires-directx-version-8-1-or-greater-to-run-on-windows-10/
Computers &... • Answered 2 days ago
Are you using a discrete video card? If so, what is the make and model of the graphics card? Press Windows key + X Click Device Manager Expand Display adapters Right click the current display adapter Click Properties Click Driver tab Click Rollback driver if the option is available If not Right click the current display adapter Click Uninstall Check the box that says, "Delete the driver software for this device." Exit Device Manager Restart Go to Start -> Settings -> Update & security, then Check for updates and install any available updates. You might need to update the display driver from the manufacturer of your computers website. If that method fails to work, check out this article: 6 Best Solutions To Fix Computer Randomly Restarts On Windows
Here is a good post that can help you with downloading music on to Android devices. Basically you will need to download one of these apps and navigate to a website that has free music to download. Top Free Android Apps to Download Music mp3 downloader GetAndroidstuff
if you are using the PC's motherboard sound I would upgrade to a soundcard. they are relatively inexpensive and easy to install. www.pricewatch.com
Daewoo Vcr Player Video Player Recorder Vcr Vhs 4 Head Logo
4 questions posted
Top Daewoo Computers & Internet Experts
k24674
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Computers & Internet
Most Popular Question
clean dvd video
  • Computers & Internet
