20 Most Recent Daewoo Dvd 600 Dvd Player Questions & Answers
How do I reset it to the factory settings?
Did you look for a reset button? Contact the manufacturer? check your manual?
1/2/2016 5:24:38 PM • Daewoo Dvd 600... • Answered on Jan 02, 2016
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors. Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters) C13 image: 173-0602-e.jpg C7 image: ac15wna-r.jpg C5 image: 173-21103-e.jpg These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors. There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it. It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
5/8/2014 4:32:13 AM • Daewoo Computers... • Answered on May 08, 2014
Need windows drivers
Yes, what`s the mainboards name ???Try to seach at the pc manufactures homepage.Good luck
1/13/2013 6:25:42 PM • Computers &... • Answered on Jan 13, 2013
Need driver for windows 7
download from manufacturers website
10/16/2010 3:47:09 PM • Daewoo Computers... • Answered on Oct 16, 2010
I have a daewoo security
Hi
I've fixed this problem on a number of monitors recently, its a very simple and easy to fix problem. But you have to take the monitor apart and replace a few electrolyte capacitors from the power supply board.
A local electronics repairer can repair this for you. or you can do this yourself. Any TV, Video, etc repairer can do this simple repair.
Here is a very good picture of bad and good capacitors I found from another fixya Expert.
Your problem is probably 1 or 2 bad capacitors, you will notice a faulty capacitor from its top, if its not flat / level, then it needs to be replaced.
Replace the capacitor with a same voltage cap, the UF rating has to be the same or it can be higher, but not lower. If for example you have one faulty capacitor in the display its 16V (16 volts) and 1000 UF, you can replace it with a 16V 1600UF capacitor for example. Would recommend to replace with the same value.
Let me know if you need further instructions or if you need help in taking the display apart or if you need anything else. I'm sure I can assist.
9/21/2010 4:10:46 PM • Daewoo Computers... • Answered on Sep 21, 2010
When i power down to standby,and start it back up,
is there a "wake up" key on your keyboard? if yes,try using that?
2/4/2010 12:56:00 PM • Daewoo Computers... • Answered on Feb 04, 2010
New fuel pump isnt working
That's because Monitors don't have fuel pumps.
10/13/2009 3:17:41 PM • Daewoo Computers... • Answered on Oct 13, 2009
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered Yesterday
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered Yesterday
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 2 days ago
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered on Apr 13, 2024
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Daewoo Dvd 600 Dvd Player Logo
1 questions posted
Top Daewoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Computers & Internet
Most Popular Question
reset factory settings
  • Computers & Internet
