20 Most Recent
Dodge 1999 Ram Van 1500 Conversion Questions & Answers
1999 Dodge Ram 1500 Van. No injector pulse on a NOID Light until you add starting fluid. Then it fires up and injector pulse returns.
If your 1999 Dodge Ram 1500 Van is not producing an injector pulse until you add starting fluid, and then it fires up and the injector pulse returns, there may be a problem with the fuel system. Here are a few steps you can try to troubleshoot the issue:
- Check the fuel pressure: A low fuel pressure can prevent the injectors from functioning properly. Use a fuel pressure gauge to check the pressure at the fuel rail, and make sure it is within the specified range for your vehicle. If the fuel pressure is low, there may be a problem with the fuel pump or fuel filter.
- Check the fuel injectors: The fuel injectors may be clogged or malfunctioning, preventing them from delivering fuel to the engine. You can try cleaning the injectors, or have them tested at a reputable repair shop to determine if they are the source of the problem.
- Check the wiring and connections: Make sure that all of the wiring and connections to the fuel injectors are secure and in good condition. Any damaged or loose wiring can prevent the injectors from functioning properly.
- Check the engine control module (ECM): The ECM is responsible for controlling the fuel injectors and other engine functions. If the ECM is faulty, it can cause problems with the fuel system. You can have the ECM tested at a reputable repair shop to determine if it is the source of the problem.
If these steps do not resolve the issue, it is best to have your vehicle diagnosed by a professional mechanic. They will be able to diagnose the problem and recommend the appropriate repairs.
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
My syncmaster 2250P is uncalibrated
You may be able to find some suitable settings for your SyncMaster 2250P monitor by searching online or consulting the manual. Alternatively, you can try using a calibration tool such as the SpyderX Pro to accurately adjust the gamma, color, and saturation of your display.
How can a white screen on a laptop be fixed?
Here are a few steps you can try to fix a white screen on a laptop:
Restart the laptop: Sometimes, simply restarting the laptop can resolve the issue.
Check the cable connections: Make sure the cable connections between the monitor and the laptop are secure and properly connected.
Update the graphics driver: Make sure the graphics driver is up-to-date. You can do this from the device manager on your laptop.
Run a virus scan: A virus or malware can cause a white screen, so running a virus scan can help determine if this is the case.
Perform a hard reset: This involves disconnecting the laptop battery and unplugging the power cord, holding the power button down for 30 seconds, then reconnecting the battery and power cord and restarting the laptop.
Boot in safe mode: Boot the laptop in safe mode and check if the white screen still occurs. If it doesn't, the issue could be with a recently installed application or driver.
Reset the laptop to its original factory settings: If none of the above steps work, resetting the laptop to its original factory settings may resolve the issue.
If these steps don't resolve the issue, it may be a hardware problem, and you should consider taking the laptop to a professional for repair.
Drivers for b140d unable to connect to computerl?
:It is possible that the drivers for the B140D are not installed correctly or need to be updated. I suggest downloading the latest drivers from the manufacturer's website and installing them on your computer. Additionally, make sure all connections are secure to ensure the device is communicating properly with the computer. If the issue persists, then you may need to contact the manufacturer or a qualified technician for further assistance.
Bernina 440 ec pc help
It sounds like there could be an issue with the connection between your computer and the machine or with the connection software. I suggest double-checking all connections and ensure that the connection software is installed correctly on both devices. If the issue persists, then you may need to contact Bernina for further assistance.
