20 Most Recent
Frigidaire FDE647RF Dryer Questions & Answers
Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Dryer making noise fde647rfs0
Check the drum rollers, they may need some oil. Next I would check the condition of the belt. It's a relatively cheap and easy fix.
How to remove the drum from the front and replace the drum support cup kit.
Release the top by pushing in the clips with a putty knife at the front right and front left of the dryer. Once you release the top you can remove it by disonnecting the ground wire at the rear of the top panel. Remove screws that secure the front panel to the dryer. Once all the screws are removed give the front panel a tug to pop it from the clips. Unhook the wiring harness and remove the front panel. By now you can see the drum. Remove the belt from the motor and idler wheel pulley. Yoy will need to get to the rear of the dryer and remove a grill (lower left corner).to gain access to the pulleys. Once the belt is removed, grasp the drum at the rear and give it a quick **** upward to release the drum from the rear bearing. The drum can now be removed through the front.
If you are replacing the rear bearing, consider also replacing the front plastic glides/slide that are located at the top of the door.
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
