20 Most Recent Brother SQ9000FS 80/120 Stitch & Alpha FONT Computer Sewing Machine, 8x1StepBH 7mmZZ WalkDarn1/4Foot 10Feet Theader 10Lb ExtTable 2CasesXR9000 XR9500 Questions & Answers
Try a different brand new needle. Make sure it is facing the correct direction when installed. If it is still hitting, you need to take the machine for service.
Brother SQ9000FS... | Answered on Mar 09, 2018
The "thread out" sensor can be triggered if the thread is not between the tension disks. That is usually caused because you threaded with the presser foot DOWN. You MUST raise the presser foot when you thread your machine; that is the only time that the tension disks are spread to accept thread.
Brother SQ9000FS... | Answered on May 11, 2015
Make sure presser foot shank is installed correct. The presser foot bar may also need some oil.
Brother SQ9000FS... | Answered on Jan 02, 2015
You will have to reset the timing all over again it can take a few attempts
Brother SQ9000FS... | Answered on Oct 07, 2013
If you were to download a service manual via google, that may have enough information for you.
Brother Sewing... | Answered on Jul 29, 2020
Request the manual from Brother.
Brother Sewing... | Answered on Jul 24, 2020
Had the same problem here. Took it apart and found that several tracks in the ribbon cable from the keypad to the circuit board on which the LCD display is mounted were broken hence keypad needs to be replaced. Its part number is XA4331002 and available online from Sewing World. Have just finished fitting the replacement and keypad and sewing machine are working A1 OK.
Brother Sewing... | Answered on Jul 22, 2020
Try turning unit on with foot control unplugged. If it starts on it's own with foot pedal disconnected then internal board failure (smoke).
Brother E6 error?
A.
The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
The needle could be bent. Replace the needle making sure the flat side is facing the back.
Brother Sewing... | Answered on Jul 14, 2020
Request/order from Brother
Brother Sewing... | Answered on Jul 05, 2020
Order/request from Brother
Less than 1 Second on google.
https://www.sewingmachine-parts.com/overlockers-brother-530-530d-546-546d
It is a French machine so no English.
Brother Sewing... | Answered on Jun 16, 2020
If you gargle it, google will find you a manual.
Brother SQ9000FS 80/120 Stitch & Alpha FONT Computer Sewing Machine, 8x1StepBH 7mmZZ WalkDarn1/4Foot 10Feet Theader 10Lb ExtTable 2CasesXR9000 XR9500 Logo
9 questions posted
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
brother sq9000 needle striking race
  • Sewing Machines
